Red Prius 04 With 275K Miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HarryThePrius04Guy, Jun 3, 2020.
  1. HarryThePrius04Guy
    HarryThePrius04Guy New Member
    25
    Lexington Park MD
    I have these codes from the Toyota dealership in Lexington park MD. I Bought the car in 2004. I never had the 12V replaced. The oil was changed in November. It’s due in June 4 2020. There’s no lights on or ready light on the dashboard no check engine light nothing. The car drives okay! Theres no heat or ac coming from the Prius. The battery goes fully green and back to down purple within 45 seconds. I let the car sit for 2 months while this virus was out there. I need options please help.
    C1310 - Malfunction In HV System
    C1259- HV System Regenerative Malfunction
    C1241 - Low Battery Positive Voltage
    C1242 - IG2 Power Source Circuit
    C1239 - Foreign Object Attached On Tip Of Left Rear Sensor
    C1274 - Low Output Signal Of Rear Speed Sensor Left
    C1278 - Abnormal Change In Output Signal Of Rear Speed Sensor Left
    P0A7F - Hybrid Battery Pack Deterioration
    P0A80 - Replace Hybrid Battery Pack
    P0A82- Hybrid Battery Pack Cooling Fan 1 Performance/Stuck Off
    P0AC0 - Hybrid Battery Pack Current Sensor 'A' Circuit Range/Performance
    P3000 - Battery Control System Malfunction
    P3011 - Battery Block 1 Becomes Weak
    B1421 - Solar Sensor Circuit (Short)
    B1271 - Combination Meter ECU Communication Stops
    B1442 - Air Inlet Damper Control Servomotor Circuit
    #1 HarryThePrius04Guy, Jun 3, 2020
  2. HarryThePrius04Guy
    25
    Lexington Park MD
    Forgot to mention I have this code as well
    P2112 - Throttle Actuator Control System - Stuck Closed
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    You have a couple of large ticket repairs, do you have tools and a DIY mind set, or will you be paying someone to fix the known issues?
    Does the above mean you're due for inspection and registration?
    You mentioned the vehicle drives currently, is that correct?
    16 years is a decent run for a 12v battery, what is the voltage currently reading at, and have you thought about replacing it?
  4. HarryThePrius04Guy
    25
    Lexington Park MD
    No a oil change. The 12V Was around 10 Volts it drives ok here’s some photos I took.
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    10v is quite low. If you plan on repairing and keeping the vehicle, then replacing the 12v battery would be prudent.
    What kind of options are you looking for?
  6. HarryThePrius04Guy
    25
    Lexington Park MD
    I was thinking Toyota but they want over 5,000$ I was looking for ways to fix this!
  7. bisco
    52,826
    newpriusbatteries.com
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  9. HarryThePrius04Guy
    25
    Lexington Park MD
    Do they install it for me? I want a new battery not rebuilt
    How much would they cost if I wanted a new one.
    #9 HarryThePrius04Guy, Jun 3, 2020
  10. bisco
    52,826
    'brakeactuatorsareus.com
  11. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Hmm. We’re having trouble finding that site.
    We can’t connect to the server at brakeactuatorsareus.com
    If that address is correct, here are three other things you can try:
    • Try again later.
    • Check your network connection.
    • If you are connected but behind a firewall, check that Firefox has permission to access the Web.
  12. HarryThePrius04Guy
    25
    Lexington Park MD
    I would like to know if you can reset and keep driving without fixing the problem
    What’s the different between an 04-05 combination meter and 06-09? Aren’t they all the same since gen 2 is 04-09?
    Can the hybrid Battery be fixed if I were to replaced the one cell?
    #12 HarryThePrius04Guy, Jun 3, 2020
  13. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Excellent. So you have some time, tools and a can DIY attitude (y)
    http://www.newpriusbatteries.com/ only sells new aftermarket HV battery kits, you or an installer would have to do the install.
    Though possible, not for very long. And if you're lucky one or more of the modules won't explode :whistle:
    04-05 top out at 299k, otherwise the same.
    Yes, but it may take more than a single module and most likely balancing. Will it last as long as a new battery, not even close.
    Raytheeagle likes this.
  14. HarryThePrius04Guy
    25
    Lexington Park MD
    So where can I buy a new battery?
  15. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  16. HarryThePrius04Guy
    25
    Lexington Park MD
    Do they do installs as well? Where can I get a new fan and regenerative breaking at?
  17. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Best to ask @2k1Toaster (aka Mr NewPriusBatteries) if there is a local installer that can help you.
  18. HarryThePrius04Guy
    25
    Lexington Park MD
    Would it better if I had a company do my battery?
  19. HarryThePrius04Guy
    25
    Lexington Park MD
    Theses guys fix combinations meters and hv battery regeantive breaking and 12v it would fix most of my problems what do u think? I think they can replace the cooling fan as well. I have triple AAA so if needed to tow it up there I can! Prius hybrid repair in Annapolis md I’m in Lexington Park MD. If so I would in after I get a oil change bc I’m super low on oil
    #19 HarryThePrius04Guy, Jun 4, 2020
  20. ETC(SS)
    7,533
