Red Prius 04 With 275K Miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HarryThePrius04Guy, Jun 3, 2020.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The 12V Was around 10 Volts
    I just about sprayed my drink all over the computer, lol.
    Personally, I would fix the obvious first, before I invested a lot of money into anything else.
    Get the 12v system sorted out first. Without a good 12v battery/system, you're just peeing in the wind. That may be enough to get the Combo meter working again. Once you're able to start the car, try to force charge the HV battery. Your HV battery probably has some weak modules that self discharged while dormant. They may charge well enough to get the car operational again. Somewhere down the road, weeks, months or years (who knows) you may need to replace the battery.
    Just because a Prius sits for a month and a weak module in the HV battery self discharges low enough to trigger the codes doesn't mean the module won't accept a charge and recover enough to get the car working again.
    #21 TMR-JWAP, Jun 4, 2020
    SFO likes this.
  2. HarryThePrius04Guy
    HarryThePrius04Guy New Member
    25
    Lexington Park MD
    So I took the battery out today and found this and took my cooling fan out for a quick look 85DBD126-0195-4180-84E5-961BFCC508A6.jpeg 9E306981-A41A-4041-955A-41D3BEF89E3A.jpg
    SFO likes this.
  3. HarryThePrius04Guy
    25
    Lexington Park MD
    I need some ideas block 1 tested at 12.3 while all the others were at around 14V
  4. George W
    George W Senior Member
    939
    520
    San Antonio
    I recommend dis-assembling your fan. No matter how delicate a Pick you may have, there are too many crevices inside that housing.
  5. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Keep in mind, that the copper busbars are sandwiched between the nut seating surface and the base surface of the module threaded stud. VERY rarely does the corrosion spread to that area. Think of it like this...although the outer surface of the nut and copper busbars has corrosion, it's electrical conductivity should be unaffected as long as the copper is clean in the surface contact area. If you turn on a floor lamp, then spray paint the power cord, does the lamp stop working?
  6. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Then one or both of the modules in Block 1 has a discharged/failed cell inside. If all the other blocks are 14.x volts, they're also very weak. How long has this battery been sitting? I have modules that have been on a shelf for a year and are still 7.5-7.8 volts each.
    Any chance that your car has tried to start, but just spun the engine without it actually starting? Do this a couple times, and the battery becomes drained to the kind of voltages you're seeing.
    George W likes this.
  7. HarryThePrius04Guy
    25
    Lexington Park MD
    Maybe but they all looked balanced besides block 1 current sensor A where is that? I have P0AC0
  8. HarryThePrius04Guy
    25
    Lexington Park MD
    The car sat though the end of March through June
  9. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    ok, let me provide some recent examples. I have about 1300 modules in the shop, and I've been doing a lot of cycling lately to refresh ones that have been idle for many many many months.
    The individual modules are rated for 6500mAh when new. Think of it as when they are 100% charged, they have 6500 units of energy inside.
    Here's some data from one pack of 28 that finished last weekend.
    I always record the initial module voltage and then do a discharge first to document how much energy is remaining in the module.
    25 of the modules were 7.63 to 7.73 volts and contained 2500 to 3350 units of energy, even after sitting almost a year.
    1 module was 7.31 volts and contained 499
    1 module was 7.18 and contained 408
    1 module was 7.35 and also contained 408
    So now, if you're saying all your other blocks were about 14 volts, then those modules (2 per block) are averaging only ~7 volts each. See where I'm going with this? If that is the case, they're sitting at less than 5% state of charge. That is a big problem.
    SFO likes this.
  10. HarryThePrius04Guy
    25
    Lexington Park MD
    But isn’t 14v ok if I get block cell then with 14v wouldn’t charge evenly?
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    What I'm saying is that it appears to me that your problem isn't that you have a single module failure. It appears to me (if your voltage readings are accurate) that your HV battery has severely depleted itself across ALL modules. The one that's reading 12.x is just a result of the severe depletion, not necessarily due to a module failure.
    I've seen this a couple times in Gen 2s that have run out of fuel. The battery depletes itself trying to run the car or trying to restart the engine. After a few attempts, what was once a good strong battery is now a severely depleted battery with all modules very weak and one, two or three modules that are in the 6 volt range. Especially if the 12v battery is disconnected and then reconnected. Then the SOC indication resets to about 60% default value and it tries to start the engine again, resulting in even more depletion, until the battery is effectively useless.
    The last time I helped someone with this problem, the battery 100% fully recovered just by recharging the modules. No module swaps were required.
  12. HarryThePrius04Guy
    25
    Lexington Park MD
    Toyota gave me this a day or two ago cell readings
  13. HarryThePrius04Guy
    25
    Lexington Park MD
  14. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Is there a line item on your documentation that shows what current draw was at the time the voltages were taken? A larger current draw will cause voltages to be lower. That may be why they're showing in the 14.x range. If it's a decently large draw, then those voltages could be totally normal, except for block 1, which definitely has at least one module failing.
    SFO likes this.
  15. HarryThePrius04Guy
    25
    Lexington Park MD
    Well I used my Volt meter and they were at 14 there isn’t because Toyota sent me that screenshot two day ago
  16. HarryThePrius04Guy
    25
    Lexington Park MD
    Anyone know where sensor current A is located? 0734CE11-A658-4F07-A78B-2EBB5567134A.jpeg
  17. HarryThePrius04Guy
    25
    Lexington Park MD
    Also I got a new 12v battery optima today at Napa at 12.99 Volts.
    SFO likes this.
  18. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Raytheeagle likes this.
  19. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    OK, there can be a big difference between voltage readings on TechStream while the car is live (with battery under load) and voltage readings taken when the battery is removed and under no current load. If you are measuring 14 volts on the blocks while the battery is removed from the car, then post 31 applies. The battery is depleted. This also assumes the voltage readings are accurate.
    It is very likely that you don't need to disassemble the battery. If your voltages are accurate, it merely needs charging.
  20. HarryThePrius04Guy
    25
    Lexington Park MD
    Well I still need battery current sensor a bc it was broken
