Red Triangle - 2007 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Aug 24, 2015.
  1. tampaite
    tampaite Member
    237
    42
    FL
    Nevermind the True 2 Start Battery is NOT the 12v battery.
  2. JC91006
    16,936
    8,647
    yes the TrueStart battery is the 12v battery.
    52,849
    84 months = 2 years echange, then, decreasing pro rata.
    maybe you should just order the optima.:cool:
  4. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Best call them up to verify, don't believe it is spec'd for the prius.
  5. tampaite
    tampaite Member
    237
    42
    FL
  6. tampaite
    tampaite Member
    237
    42
    FL
    Question: Once I get the battery, do I need to charge it or can I go-ahead and install it As-IS ?
    Also, where to dispose existing battery?
  7. RobertK
    RobertK Member
    128
    Norfolk, VA
    The 84 month warranty on the Toyota battery is prorated, while the Optima is a three year free replacement warranty. I think the Toyota replacement schedule goes like this:
    Months 1-24 - free replacement
    Months 24-48 - you pay 50% of the current MSRP
    Months 49-84 - you pay 75% of the current MSRP
    You might get a great deal on the initial purchase of the Toyota battery, but a warranty replacement could end up costing you more that what you paid for the battery in the first place. With the Optima you can buy any battery you want after the 36 months expire, taking advantage of whatever pricing is available at that time.
    Some battery makers and sellers are going away from prorated warranties. I just bought an Interstate battery at Costco for my Volvo, and it came with a 42 month non-prorated warranty rather than the 72 month prorated warranty that their old battery cam with.
  8. bisco
    52,849
    check the cold voltage and if it's below 13.0, put it on a trickle/smart charger before installing.
    i believe toyota is required to accept your old battery.
  9. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    You should be able to take the old batteryto all auto parts store, nearly all big chain repair centers (Firestone Tire, Midas, Sears, etc), even Wrongmart, for proper recycling & disposal. Even you smal repair mechanic might take it.
    Just call the place before, to confrm.
    tampaite likes this.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    No one has mentioned this yet. If the OP has a base model (no SKS) Prius, that big Optima battery he ordered from Amazon is NOT going to fit correctly until the battery tray is changed. Also, if by chance the Prius he has the older D45 Optima installed now he may find the posts/clamps are NOT going to jive with the newer Optima that he just purchased. D45 battery had the standard posts whereas the newer Optima is now coming with the smaller JIS post's which is identical to the OEM battery.
    Let us hope that the OP is simply changing a original battery and that his Prius has SKS on it which would take the bigger battery. Those of us in the know are aware that two different size batteries were used in the Gen II Prius. The hold down clamp is the same for both batteries, but the tray changes depending on which battery the Prius needs.
    Hope this helps the OP and clarifies things a little more.
    EDIT: I mentioned D45 Optima, I am mistaken. It was a D51 Optima. Sorry guys, brain fart...
    Ron (dorunron)
    #30 dorunron, Aug 26, 2015
  11. tampaite
    tampaite Member
    237
    42
    FL
    Got the battery delivered but it looks to be a little bigger than the original one. I measured it and it's about 8 inch tall and 9 inch length and it likely will fit. I haven't tried to install it yet.
    The analog multimeter shows approx 12.6 to 12.8 volts
    How do I know what is the manufacturer date on the battery? I see 2 and 14(see third photo) - does this mean 2nd month of 2014.
    Should I return it since its NOT manufactured in the last 2-3 months?
  12. tampaite
    tampaite Member
    237
    42
    FL
    There is a non-spillable label sticked with 509253xxxx - how do I interpret this?
    Does the warranty start from the date of purchase or date of manufacture?
    Also, this is made in Mexico.
  13. dorunron
    3,318
    1,105
    Houston, TX
    Based on the OP's pictures he has a easy job ahead of him. Pull out the OEM battery, fit drain tube to yellow top, and the install yellow top. Can't tell if he has the little or the big battery.
    For the record, the Optima DS46B24R is the battery for the Prius that is equipped with SKS. If the OP"s Prius is a BASE model, he/she will have to change the tray to get the hold down clamp to work properly and the battery to fit correctly.
    Also, there is a link below that details how to R&R the 12 volt. Good details that includes tools needed as well as tips on how to work with the hidden screw on traction battery duct. See post #8 in the link for more info.
    How do you replace the 12v battery? | PriusChat
  14. tampaite
    tampaite Member
    237
    42
    FL
    Optima_Installed.jpg Alright. Installed it :) - very easy job if you have the right socket wrench but once you remove the nuts and disconnect the battery terminals, its easy peasy.
    Test drove with the Optima battery - On power up it shows 12.1v and while driving it shows 14.1v.
    Thanks everyone - you saved me about $100 but more importantly, I was able to Do It Yourself(DIY) :cool:
    The only thing left bugging me is the manufacture date of the Optima battery.
    #34 tampaite, Aug 26, 2015
    dorunron and bisco like this.
  15. bisco
    52,849
    i would contact them about the warranty, it should start at installation. and ask about the mfg date as well.
  16. tampaite
    tampaite Member
    237
    42
    FL
    You mean the system will prompt for Mfg date?
    I sent an email to [email protected]. Let's see if they respond.
  17. dorunron
    3,318
    1,105
    Houston, TX
    FWIW, it would be a good idea to go ahead and hook up a "GOOD" smart charger that will charge AGM type batteries. You can connect it to the jump post under the hood and the strut nut for the ground. Let the charger run until it completely charges that battery up. You should get at least 12.4 or better running the onboard test. A digital volt meter should read about 12.6 to 12.8 at the jump post when the battery is installed and "FULLY" charged. I would recommend a charging rate of 4 AMPS. FWIW, a "DIGITAL" volt meter will be more accurate than a "ANALOG" meter. You don't have to have a expensive FLUKE meter. A cheap one from Harbor Freight will do the job and give you reliable figures imo.
    Good job on the DIY! I hope you have good luck with that battery. Some here on PC have reported problems with the "yellow tops" coming out of Mexico. Optima claims the QC is identical to what it was before they moved to Mexico, but actual user's seem to tell a different story.
    Best of luck to you!
    Ron (dorunron)
  18. scott180
    scott180 Junior Member
    24
    De Pere, WI
    I purchased the Optima battery from an AutoZone down the street. They had to ship it from another store in the city. It was about $185. I was able to install it. Took some time, but it worked until I went on vacation and one of the kids left the car door open while we were gone. But that's a different thread....
  19. exstudent
    2,214
    905
    Torrance, CA
    Battery warranties are based on purchase date. OP could have bought the battery today, but maybe didn't get it unstalled until days/weeks/months later. Without a receipt, the better retailers/manufactures will go by the manufacture date on the battery.
    Do yourself a favor and get an AGM compatible battery charger.
  20. tampaite
    tampaite Member
    237
    42
    FL
    Heard back from Optima.
    5092 = 92nd day of 2015 which would be April 2, 2015 so I got a battery that was about 5 months old from Amazon.
    Amazon does have a 30 day return policy - not sure if they will offer a recent battery( about 1 month old)?
