Red Triangle - 2007 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Aug 24, 2015.
  1. JC91006
    16,936
    8,647
    The battery is good, why make it an issue?
    52,849
    it probably ships from a warehouse where no one is going to check it. you would have to contact optima and ask where you can buy a recent one. but jc says your amazon warranty is golden, so i'd stay with what you have.
  3. Father Michael
    Father Michael New Member
    Sewanee TN 37375
    BOSHE (sp?) has a 4 year fully replaceable Prius battery for about $150 (watch for sales) at PEP BOYS
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I’m pretty sure he figured out where to get one since this thread is from 2015.
  5. iMK
    iMK New Member
    Virginia
    Hey I just got 2007 Prius and I’m getting red triangle sign .
    It has 79000, hybrid battery is perfect,
    New tire (40psi) in all of’em.
    I got checked Out by authorized mechanic and he is my friend
    The sign was saying that 12v battery need to be change.
    So I changed it but after two days it’s giving me same sign .
    Would you please give any me suggestions.!
    Thanks
    Happy to be here .(new Prius owner)
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    Have you checked the engine oil level (and the other under hood fluids as well?) There are very few things on a Gen2 Prius that can trigger a Master Warning Light (red triangle of death) without setting codes somewhere. One of those is low engine oil pressure.
    Did your mechanic give you a copy of the diagnostic code scan? I expect a high end Autel scantool to be able to read all 16+ ecu's on a Prius. I like to know that the scan looked at every ecu, and yes, each one didn't have codes.
    iMK likes this.
  7. iMK
    iMK New Member
    Virginia
    Dear, mr_guy_mann,
    Thank you so much for your reply and your time.
    I’ll update that code soon.
    I haven’t got the copy yet,.
    And I will check the engine oil .
    Thanks again, I really appreciate it your time.
