Red triangle and hybrid warning light, and Check engine light illuminated! Please help!
Discussion in 'Generation 1 Prius Discussion' started by JDirtbikerR, Nov 30, 2013.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    Honestly, I have no confidence in the dealer and their ability to diagnose a bad 12V battery. I have seen numerous threads/posts on here and other hybrid forums that people say "the dealer said my battery was fine". For one thing, your Prius is not concerned with CCA but Ah or Amp hours. For him/her to tell you the CCA tells me he/she's not that sharp on the ins and outs of a Prius.
    I'm not trying to be obstinate here so pls bear with me (I am trying to help you). Here's what we know:
    1) The 12V battery is the original battery in your car. Pba (lead acid) batteries usually last about 5-7 years max. Yours is 12-13 years old, its not suprising that it read 10.X Volts (and I'll bet that's what it reads now also). Lets throw out what the dealer said and take another measurement on your battery (because everything points to it being bad (including the lack of strong turbulence in the inverter reservoir)). It appears to me that your battery cannot sustain a charge beyond a surface charge.
    2) A weak 12V battery will cause the exact symptoms you describe (and many more).
    3) You don't need an install kit for $50 from the dealer. You can order the battery and replace it yourself (very simple).
    JDirtbikerR likes this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Keep us posted on the progress
  3. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Just a newb question as I am following numerous threads. Can he just put in any 12V battery that will fit the space say from an Auto parts store? As was stated, the dealer wants $270 and one can get the best one or even an optima battery for just over $100. Are the posts or connections different in some way?
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, the posts are smaller and the battery is smaller as well. Additionally, it is vented to the atmosphere, via a vent tube, unlike most normal 12V batteries. He could temporarily mount any battery in there just to prove that's his problem but, I wouldn't recommend that as a permanent fix.
  5. JDirtbikerR
    JDirtbikerR Junior Member
    65
    2001 Prius
    Ok, thanks for your advice! (from above post as well).
    You mentioned I could mount any battery in my Prius to prove that is the problem. Will you explain this further, please? Any 12 v battery? Would it similarly work to hook up jumper cables from another vehicle, and check if the car behaves differently?
    Thank you all for your continued help..I really appreciate it!
    So for the battery, will the one currently being sold by online Toyota parts distributors work without the kit?
    I will continue to keep you all posted.
  6. JDirtbikerR
    65
    2001 Prius
    I will take another measurement of my battery this evening, and report findings. Thanks.
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    WHATEVER YOU DO, DO NOT CONNECT THE JUMPER CABLES WRONG AND REVERSE POLARITY. THIS WILL CAUSE MAJOR PROBLEMS FOR YOU!!!!!!
    No it will not work to do that. Hooking jumper cables to a dead battery simply places a huge load on the "good" battery and will not allow a transfer of voltage to the dead battery. The battery likely has a dead cell and will not take a charge. Just like a conventional vehicle with a dead battery, even when you jump it, it still doesn't start (same deal here). What you could possibly do is disconnect the bad battery completely and remove it from the car, run jumper cables to the disconnected battery cables in the car and then start your Prius. This should provide enough juice to start your car. Be careful and don't take the warning above lightly.
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Keep in mind the voltage might read ok, even if it does, that doesn't mean you have a good battery. The battery's ability to sustain a voltage under load is the true measurement of whether or not its good. If it were me, I would 100% replace my 12V battery regardless of any readings period.
    Where are you located btw???
  9. JDirtbikerR
    65
    2001 Prius
    Ok, thanks yet again!
    I'm in central Minnesota, temps are down to 4* F right now!
  10. ChapmanF
    18,212
    Just to ward off any possible confusion ...
    Toyota has used two different 12 V batteries in the Gen 1. The original one, made by GS, had small Japanese terminal posts and a capacity of 28 Ah if I recall correctly. In October of 2003 they issued a service bulletin that anybody having capacity issues with the original battery could swap for a larger one made by Panasonic in S55D23L size. That swap required an upgrade kit that changed out the tray/holddown and the terminal clamps to fit the larger posts. I think Toyota will still sell you either battery depending on what you want. The present incarnation of the larger, Panasonic battery (28800-31290) has 51 Ah capacity on the label, probably as good as anything you'd find to fit in the space, but it's priced at a premium.
    So, if the one you take out says GS, a new GS will be the easiest replacement to fit. If the old one's the Panasonic, then the tray and terminal upgrade was already done, and a new Panasonic will be the easiest one to fit. If you want the higher capacity replacement but what came out was the old GS, then the upgrade hasn't been done yet and you'd want that kit (it's not much money) along with the battery.
    If you want to go with batteries from other suppliers, the dimensions and terminal size that you need still depend on which of the two battery options you found in there to start with.
    In any case, please be sure to get a battery that has a vent-hose fitting, and be sure to reattach the hose and check that the lower end still goes through the grommet in the trunk and outside (kind of defeats the purpose if it doesn't).
    -Chap
  11. ChapmanF
    18,212
    Ah, I think we forgot to warn you that the two bleeders attach at different spots in the coolant circulation. The driver's side bleed is on the higher pressure side downstream of the pump, so when you open it, air and fluid will pump out. The one on the passenger side sees the lower pressure at the suction side of the pump, so if you open it while the pump is running you won't see anything come out, because it's only sucking air in. So by alternating the two you were just sort of giving yourself work. :)
    That's why the manual gives a more tedious procedure where you always turn the ignition off before opening a bleeder, let some air out, then close the bleeder and turn the pump back on, and repeat. But then that's harder than it has to be, too: it's perfectly fine to open the pressure-side bleeder while the pump's on, and you can also bleed from the suction side with the pump running, as long as you have a way to apply a slight vacuum on the bleed hose - anything over about ten inches of water should be enough to overcome the pump suction, which means it should be enough to just use a long enough hose to siphon down to a jug on the ground. (But you might want to prepare with some soft thread sealant for the passenger side bleeder, without which it may suck some air in around the threads while you're paying attention to the hose.
    The difference in battery price quotes you were given makes me wonder if some of them were for the original spec battery and some for the -31290 upgrade battery ... that would put them both in the ballpark. Again, the only way you could need the $50 upgrade kit was if you had the orig. battery before but you want to switch to the upgraded one. Otherwise, you'll either stay with the smaller battery and not need the kit, or the upgrade was done in the past and you don't need the kit 'cause it's already there.
    -Chap
  12. JDirtbikerR
    65
    2001 Prius
    All right. I replaced the 12V battery. I ended up going with the EastPenn Deka battery that Napa sells for the Miata, and just had to do a few modifications. All in all, it was pretty simple, and I am happy with how it turned out.
    After I installed battery, I started up Prius. Started and ran beautifully. No warning lights. Then I went and checked the inverter fluid reservoir. No turbulence.
    I can definitely hear the aquarium pump sound coming from the inverter pump, and when I feel the pump itself, I can tell that it is moving. The hoses coming out of the pump are vibrating, as well as the pump itself. At the reservoir, the hose that goes into the reservoir has no vibration, it is only close to the pump itself that it is vibrating. The hose that comes out of the passenger side of the inverter[?] has vibration all over, going from the pump to the block. I do hear a little gurgling noise coming from the pump. The level in the reservoir is the same all the way across, with the front part being no higher than the rear.
    I tried bleeding the system for a while, doing the method of ig on, ig off, open valves, close valves, repeat, and made little to no progress.
    I then experimented around with different methods, including opening both bleeder valves while having the passenger side in the reservoir.
    Note that while I was experimenting, when I had the driver side valve opened with ignition on, there was a steady stream of coolant coming through the hose that I had going from the valve to the reservoir, with no bubbles.
    At one point, I drove up and down the road, and came back and did the ig on, ig off method, and still to no avail. Note, my Prius worked good during this little drive.
    Chap, will you please rephrase your suggested method of bleeding? From what I am understanding, I should run a hose from the passenger side bleeder into a jug of coolant on the ground, then run a hose from the driver side bleeder valve to the reservoir and open both valves while having the ignition on? And have some thread sealant on the passenger side bleeder (would teflon tape work?)?
    Then, I decided that I had had enough for the night, and put both hoses I had been using into the reservoir to drain. So, all four ends were in the reservoir, with the cap off. Before heading inside, I started up my Prius one last time. When I started it this time, it shut off! The motor came to a shuddering halt, the orange triangle lit up, the hybrid warning light came on, as well as the check engine light. I got out, and went and looked under the hood area. The same noise was coming from the engine block area. I took out the two hoses I had placed in the reservoir, and when I took them out, I heard a noise that was almost like a pressure valve was released "whoop". Could there be air in the inverter system that caused the same problem to come up again?
    When I got the new 12V battery, I put it on my trickle charger, and after only about 5 minutes of charging, the charger indicated that the battery was charged. After convincing my Prius to reset (it was a little bit difficult to get the system to reset, with MG1 not spinning each time I turned the key to start), I pulled some voltage readings from the MFD. No accessories on: 11.8V. Accessories on: 10.5V. When I tried to get the voltage reading for the motor running, my Prius shut off again, with all the warning lights coming back on. This time, I left it be, and didn't reset it. According to eLearnAid, these readings were a little low. I don't think the numbers I got are a true reflection of the health of the new battery, due to all the turning on and off.
    Thoughts? Ideas?
    Thanks, all, for sticking with me!
  13. bwilson4web
    16,217
    My understanding is the usual inverter pump failure mode is no noise or motion. What you are describing suggests:
    • blockage
    • air in the pump
    Regardless, no fluid flow, no cooling of the inverter. Although normally the car detects the overheating and turns it off. But like a reserve parachute, there is no guarantee . . . just hope.
    Please put your tickle charger on the 12V again and measure the voltage after it shuts down. You want to see ~12.8V in a new battery with no load other than the trunk open.
    When (if) you get the car to run again, measure the 12V circuit. If everything is working, we would expect to see 13.8-13.9V. If not, the 12V DC-to-DC converter is toast (i.e., time to replace the inverter.)
    Need to find out if the inverter coolant loop is blocked or just air-locked. If I had to do this, I would try to use air-pressure to blow it clean. But wiser heads may have better method.
    GOOD LUCK!
  14. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Well not sure if I am correct ,but you may have 2 issues. One, the coolant pump still has air in it or its blocked. 2 it could be that the invertor 12 volt system is not recharging the battery,hence the reason it shut off due to low 12 volt. Where are you located? there is a chance somebody may be close to you and could help you out. ..keep us posted. FYI you could keep a charger on the 12 volt battery and than try to bleed the air out of the system. I usually leave the key on engine off and play with the 2 screws till i get it bled out. With the charger on the battery it will also eliminate one of the 2 reasons the engine shuts off.. invertor hot or battery voltage low..
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    I def agree with yota, it looks like two problems to me. You def don't seem to be charging your 12V battery and that's why you're having all the problems.
    I have to be truthful here and say apparently some of what I said in previous posts on this thread were wrong. It appears as if his original, 12 yr old 12V battery may not have been bad. It looks like I jumped to an improper conclusion based on my personal observations with dealer techs. I find myself wanting to say something like "its prudent to replace it anyway" but, I don't even know if that's the case here. I do know that some of the advice I gave was likely wrong and I feel terrible about that. I hope I didn't cause the OP too much trouble.
    But now, we do know that we have a good 12V batt. and we still have the same problem so, let's keep trying to fix it (if you still have any confidence in what I say).
    Pls run this test, charge the 12V battery to full (unhooked from the car), turn the car to start and release, if it starts, go back to the trunk and measure the voltage at the battery or at the fuse box jump point. It should read about 14. Report the results here. If it reads below 13, I would suspect the 12V charging circuit in the inverter is bad (that's one problem).
    The other problem we have is the lack of circulation in the inverter coolant loop. If the pump is running then blockage and air are the two likely culprits.
    The stable 12V battery/inverter problem should be tackled first (in my humble opinion (and much more humble now)).
    JDirtbikerR, yotatoter and Zedhomme like this.
  16. JDirtbikerR
    65
    2001 Prius
    All right. I got a multimeter now, and went and checked the voltages.
    I should note, I tried charging the battery with the cables hooked up, and it wouldn't charge; the problem light on my charger came on and it refused to charge it. The problem light also illuminated while I tried keeping the charger on the battery while trying to bleed the inverter system. When I unhooked the battery cables, the battery charged up.
    The battery charged up, so I unplugged the charger last night. This morning, I plugged it back in, and after about 5 seconds, the charger said it was charged.
    Here are the voltages:
    Battery completely charged, cables unhooked: 12.85V
    Cables hooked up, only trunk light on: 12.71V, then dropped to 12.6V after a minute or two with the trunk open
    Car on: 13.89V, continuously for the 30 seconds I checked it
    -Note, the car turned on, and ran fine while I checked the voltage with it on. It was running for about two
    minutes. Still, there was no turbulence in the reservoir.
    Car off: 12.70V, slowly went down to 12.56 after a couple minutes
    Car off, trunk closed for a couple minutes: 12.59V
    When I tried leaving the charger on the battery with the cables on the battery, the charger refused to charge the battery. Same for when I tried charging with the ignition on, while bleeding. The charger did work when I unhooked the cables (terminals).
    I'm in central MN, btw, about an hour west of the Twin Cities.
    No worries, usnavystgc, no worries. I realize its good to replace the battery anyway. The last thing I want is to be stranded somewhere in this cold MN weather, with no one having a battery in stock that would fit (the dealer close to me doesn't even carry the battery for my Prius). See information in this post further up for a detailed listing of voltages. With the battery fully charged, I started up my Prius. Voltage was 13.89V.
    Thanks again, all!
  17. JDirtbikerR
    65
    2001 Prius
    Update: a family friend who is a mechanic came over this afternoon. When he started my Prius up the first time, it ran for the couple minutes it was on. He shut it off, turned it back on again, and Prius did the same shut off routine that has been occurring. He then was able to read code P3191 (engine does not start) on his Innova scanner. Still no turbulence in the reservoir.
  18. Patrick Wong
    18,210
    6,510
    Regarding DTC P3191, try cleaning the throttle body interior and throttle plate using throttle body cleaner. Don't contaminate the mass air flow sensor while doing this process.
    If there is no turbulence in the inverter coolant reservoir but you hear the inverter coolant pump running, then you know you still have air in the inverter coolant loop and this must be fixed before you drive the car.
  19. usnavystgc
    3,159
    990
    Tucson, AZ
    No turbulence has to be fixed at all costs. I would address this first. My question is, are you 100% certain the inverter coolant pump is running? If so then you need to follow the procedure to bleed that loop until there is no air in the system. It takes a lot of patience.
    Judging by those readings, yer inverter is working fine so that's good.
    Good luck
  20. JDirtbikerR
    65
    2001 Prius
    Thank you. Are there DIY guides on cleaning the throttle body plate and interior here on PriusChat? Should the MAF sensor be cleaned at the same time?
    I am 95% certain. I can hear an aquarium pump noise from behind the driver side headlight, and can feel it moving when I put my hand on it. When I open the driver side bleeder, fluid comes out right away, and it flows out at a fast rate.
    Will you will please explain how to use air pressure to blow it clean, clearing out any blockage? Would it work to drain out the coolant, then attach a hose from the bleeder valve to my air compressor blower nozzle, and blow through each bleeder with the drain plug open?
    I did try the bleeding method that Chap suggested for a couple hours, and had flow out of both valves. Throughout the process, I massaged the hoses, and while bleeding, pockets of air came out over the course of an hour and a half or so, with no activity the last half hour. With a line going from the passenger bleeder to a jug of coolant on the ground, and a line going from the driver side bleeder to the reservoir, I had to top off the reservoir every few minutes, as fluid kept draining into the jug on the ground. The entire time that I was bleeding, the level in the reservoir was pretty even all the way from front to back of the reservoir. While I was bleeding, I did keep the level above full, as the front part of the reservoir was not higher than the back part, and it appeared as though keeping it at the full mark would cause the level in the front to be below the top of the hose that goes into the front of the reservoir.
