Red triangle and hybrid warning light, and Check engine light illuminated! Please help!
Discussion in 'Generation 1 Prius Discussion' started by JDirtbikerR, Nov 30, 2013.
  1. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Well during my Minnesotan commute this morning the Prius said -20* F and the Turtle was on for almost 30 miles during my 45 minute drive. Brakes were very stiff as well as steering to start out. I did not go over 60 mph and felt like it took for ever to get up to speed for fear of the turtle. My Prius turtle has been on daily for weeks. It took me two turns of the key to get the ready to start the car. Checked battery yesterday and it read 13.8 volts. For sure change the plugs and use the iridium plugs which I think I paid about $9 each. when i did mine I think I only removed the black relay/fuse box above where the plugs are and was able to get access to them all. Took less than 30 min. Wish the Prius had a block heater as my other vehicle has one and it turned over quickly.
    TomK
    JDirtbikerR likes this.
  2. Patrick Wong
    18,200
    6,502
    1. The 12V battery needs more charging or should be replaced. What are you using to charge it, how much time are you giving to the charge and what charging current is being used? Should be charged overnight at a 4A rate.
    2. Yes, you should replace the PCV valve while you are at it. You can try removing the valve without taking off the cowl tray, but if you don't have adequate access it is not very difficult to remove the windshield wiper motor and cowl tray.
    3. Yes, P3191 would be stored even after the CEL turns off on its own.
    4. The orange turtle light means that you need to restrict power train output because the traction battery has a temperature related issue: either too hot or too cold, both of which significantly restrict power output. In your case, probably the latter. Note that 2G and 3G models do not have this light.
    5. If P3013 returns, you will need to work on the traction battery.
    6. When referring to the radio being fuzzy, I assume you are tuned to an AM signal. How many miles away are the transmitters from your location and are they located in a major city or some small town? An intermittent fuzziness may point to a bad ground connection at the antenna base. And an AM transmitter in a major city may operate at 50 kW power output while an AM transmitter in a small town may operate at 1 kW output, so there is a big difference regarding the effective range of those stations.
  3. JDirtbikerR
    JDirtbikerR Junior Member
    65
    2001 Prius
    Thanks. Brr, I am freezing right along with you here in MN! As far as the block heater goes, I installed one in my Prius. It was fairly simple, and they can be bought for $50-$60 online. I bought mine on eBay from metrotoyotapartsnow (Jesse at Metro Toyota) for $49, free shipping. I later found out that they available on PriusChat website, and part of the purchase supports the website. When I installed mine, I did it from the top, removing the windshield wipers, ww motor, and plastic and metal cowling. Many guides are available here on PC.
    1. I'm using an automatic 1.5 amp charger, and using the battery after the charger indicates that the battery is charged. I leave the charger going overnight, but I don't know how much time it gets charged for before the charger deeming it full. Last time when it finished charging, battery voltage was 13.05V. Is there more to a proper charge than the resulting voltage reading being close to 12.8V? If the battery keeps refusing to hold a charge overnight, do you think I will be able to convince the Napa store I bought it from that it is defective?
    2-5. Thanks for the information and advice!
    6. I am referring to both AM and FM. While on FM, I experienced clear sound, then a sudden burst of fuzz, clear sound, fuzz. Both times this has happened, 12V battery voltage has been lower than it is supposed to be. But in the last instance, would a voltage of 12.21V cause radio issues? And the first time the fuzz happened (tuesday night), FM stations that usually are crystal clear were nothing but fuzz, in fact i was unable to find any station with clear playback.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    That's really weird about the radio because there is no reason that should happen. I wouldn't put too much thought into that but I would keep it in the back of my mind because it is after all a possible symptom (of what I don't know). It could just be an anomoly.
  5. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Mine also has had this crackling sound until it warms up. Very loud actually to where I turn it down. It has done this ever since it has gotten cold, probably below 15* F. So about everyday, ha! Thanks for the info on the block heater! I will look into it as this is my fifth vehicle and it sits outside my three car garage.
    TomK
  6. Patrick Wong
    18,200
    6,502
    1. The voltage measurement needs to be taken after the battery has rested undisturbed overnight. A voltage measurement taken immediately after charging is not very helpful due to surface charge which overstates the actual battery state of charge. Also, a 1.5A charger is close to being a toy and not too helpful for automobile batteries which are severely discharged, so you may consider getting a charger with greater capacity, intended for AGM batteries. The Prius battery has a label which suggests using a 4A charging rate.
    6. When you have some time, wobble the antenna base with your hand, while the radio is on and see if that causes the burst of noise vs. clear signal.
  7. JDirtbikerR
    65
    2001 Prius
    Very peculiar that the radio does this.. You are welcome! I notice that my Prius warms up much quicker with the use of the block heater.
    1. Ok, I'll look into getting another charger. Thanks. Should I take voltage reading after Prius has sat overnight outside with cables plugged in, or after sitting in shop overnight with cables unplugged, or some other method?
    6. I'll give this a try the next time I get fuzziness.
  8. Patrick Wong
    18,200
    6,502
    Well, the most stringent test of the battery is when it is sitting outside, suffering in the Arctic-survival temperatures that you are dealing with now. It might do better indoors, but since the battery has to perform outdoors, that is where the test should be conducted.
    It should not matter much whether the battery cables are connected since the quiescent current draw of Classic should be around 0.03A.
  9. JDirtbikerR
    65
    2001 Prius
    I experienced a bout of warning lights again tonight. Due to the extreme cold, I've had Prius plugged in for most of the day while I was working. When I left my workplace, the orange turtle light was on, it remained on for the entirety of this journey. After about 8 miles of driving, the hybrid warning light, CEL, orange exclamation triangle light, and brake light all came on. The engine revved up, and I lost power. When I stopped on the side of the road and put Prius in park, the engine stabilized. I got out and took note of air/ fan noise coming from hybrid battery vent, and noted a step in the inverter reservoir. I didn't look if there was turbulence. The outdoor temperature was -15* F, and the cabin was not warm when lights all came on. I shut down Prius, left key on "Acc" for about five minutes. After calling AAA and learning of a 20 minute wait time just to speak with a representative I decided to slowly drive the three miles home.
    After Prius had been sitting in shop with temps around 50* F, I checked the battery voltage: 12.31V.
    I ran the DTC's, and retrieved code P3011.
    How possible is it that the extreme cold is triggering these codes (I'm assuming that this code is another hybrid battery related one)? And what potential harm could result in continuing to drive Prius as is (assuming that this is the only problem), and hoping that it will work when the temps warm up?
    Thoughts, ideas, advice?
    Thanks again!
  10. Patrick Wong
    18,200
    6,502
    I would have liked to know what is the 12V battery voltage measurement at the moment when all the warning lights turned on, while the Prius is still READY. Pls bring your digital multimeter in the car so you can take that measurement next time this happens. You can measure voltage at the 12V aux power socket. Maybe your DC/DC converter is having an intermittent failure.
    The very cold weather is stressing the traction battery and P3011 (pointing to the first battery module pair) is probably legitimate. You'll need to take remedial action with the traction battery eventually.
  11. JDirtbikerR
    65
    2001 Prius
    I actually had my multimeter with me at the time, too bad I didn't think to check the voltages at the time. I will keep it in Prius now, and measure voltage the next time this occurs. How can I measure voltage at the 12V aux power socket?
    I'll try using my 1.5A charger to charge up battery again, then take voltage readings of battery in the morning. Hopefully it will finish charging tonight so I can remove the charger. I'll park Prius outside while it charges.
  12. Patrick Wong
    18,200
    6,502
    Look into the power socket, with a flashlight if needed. The center contact deep within the socket is the positive terminal. Try not to short that to ground, which would be a metal contact running around the inside of the circular opening.
    You might also measure voltage at the 12V battery and note any significant differences.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    I think I'm starting to see a clear picture emerge from the clouds here. I believe all these problems stem from a weak HV battery. The weak HV battery is causing the turtle light then while driving, battery block 1 becomes weak (P3011) and triggers the faults and the rest of the lights come on. This is compounded by the cold weather which we know steals capacity from a battery.
    My diagnosis is (if you want it) your HV battery (specifically block 1) is weak. You are at the beginning stages of module failure and that's why the car drives. I would not recommend driving it and def not in this cold weather for fear you will get stranded in a no cell phone coverage area. I know we do have a concern about the DC - DC converter in the inverter but I don't see how that would cause a Master Warning Light and a p3011.
  14. JDirtbikerR
    65
    2001 Prius
    As I mentioned earlier, the other time a battery related code came up (last Tuesday), the code was P3013. Does P3011 also coming up indicate at least 2 problematic cells?
    As an aside, is it normal for the MFD to show the hybrid battery level completely full at times? I've noticed this at times these past few days while I have been driving and keeping the screen on "Energy". I usually keep the screen on "Consumption", and can only remember seeing the battery level completely full once before, and that was after going down a lengthy hill. The reason I ask is I thought that battery level never charges past 80%.
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    No, that's totally not normal and should be rare (ie from going down a hill). That is further evidence of your HV battery beginning to fail.
    An your are correct about the 80% but that would be a completely green battery on the Energy screen.
  16. JDirtbikerR
    65
    2001 Prius
    This is what I have been seeing, a completely green battery on the MFD, while I rarely have seen this before, although I usually keep the display on consumption. I don't know how to check the actual level, if the level displayed on the MFD isn't reflective of the actual percentage. How can this be done?
  17. Patrick Wong
    18,200
    6,502
    The traction battery ECU attempts to maintain state of charge between 40% and 80%. The Classic SOC gauge has four segments to it, so if you see a completely green battery where all four segments are lit, the SOC is ~80%. If no segments are lit, the SOC is ~40%.
    Typically the Classic SOC gauge will either read two or three segments when the traction battery is properly operational, which means the state of charge ranges from 60% to 70%.
  18. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I tried to figure that out today as I read the earlier post. My conclusion is that it must just be a visual graphic and not a percentage of the battery charge on the ENERGY screen. I could not figure it out so if there is a way I would like to also know. I however do not understand most of the settings this has yet, but would like to.
    TomK
  19. JDirtbikerR
    65
    2001 Prius
    I drove Prius again today, and warning lights came on again, twice. Outdoor temp was 0* F, and the turtle was not on. The symptoms that occurred were the same as previously described. The first time the warning lights occurred, I panicked and forgot to check voltage. I had driven about 10 miles, this was in the evening after Prius was outside all day at work. I shut Prius off, and pulled code P3011. I erased the code. Then I continued at highway speeds (somewhat thinking it would happen and I would be able to get voltage readings), and drove about 3 miles before lights came on again. This time I pulled over, and retrieved voltage from 12V plug with Prius remaining on. 13.79V with Prius running, 11.51V with Prius not running, key on with indoor lights and headlights on, 11.51V with key off, lights still on. This time, DTC P3011 AND P3014.
    I did not check the voltage at the battery, much too cold outside. Tmrw, I will check if there is a difference in the readings from the different locations. Perhaps any difference can be extrapolated?
    My battery had not finished charging last night when I checked it, so I was unable to get the voltage for overnight undisturbance. I have battery charging again, so I will remove charger in morning and check the voltage after it sits all day.
    So now, three separate hybrid battery related DTC's have come up. When the hybrid battery begins failing, is it normal for several modules to start having problems in a short period of time? Or is it likely that there is another problem that is triggering failure of hybrid battery?
    At this point, for battery repair, what are my options?
    1. Replace with new battery.
    2. Replace with refurbished battery.
    3. Replace bad modules with Gen 2 cells.
    Any others?
    Ok, thanks. This makes sense.
    Tom, it looks like both you and Patrick posted at the same time. Patrick explains the MFD hybrid battery SOC well in post 77.
  20. Patrick Wong
    18,200
    6,502
    How many miles a day are you driving the Prius?
    I recognize that your ambient temps are very cold, but I am wondering why the battery voltage that you reported below is so low, when Prius is not READY. That seems lower than I would expect for a new 12V battery which is supposed to be fully-charged.
    When you took those measurements, was the cabin heater on? If yes, maybe the PTC electric heaters were on, which would provide a further substantial load on the 12V bus (around 50A extra.) Turn off the heater and see if that matters to the voltage measurements.
    I also am wondering why the 12V battery is taking so much charge, and suggest that you need to invest in a better battery charger now, intended for AGM batteries and with a charging rate of at least 4A.
    Obviously a charge rate of 1.5A is insufficient. Maybe the new 12V battery has less capacity than it should, which causes the voltage to sag down under load.
    Yes, you've identified the major options for traction battery replacement below. Considering that the battery is 13 years old, and the adverse cold temperatures you have, it is not surprising to me that multiple modules are starting to report problems. This is why it is a waste of time to just replace one module at a time unless your idea of a hobby and fun is to continually remove and work on the traction battery.
    JDirtbikerR and usnavystgc like this.
