Red triangle and other red warning image?
Discussion in 'Gen 2 Prius Technical Discussion' started by mercat68, Apr 13, 2019.
  1. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    I’ll leave It to @2k1Toaster to explain - he’s pretty explicit in the instructions that it’s better for his set-up to put them on the top side.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Did you use an inch pound torque wrench when tightening the module.hardware? Or did you simply guess on tightness?
    Often guessing can leave to under tightening or over tightening. Which can lead to damage or incorrect data.
    Same thing for the HV connections at the relays.
    Raytheeagle likes this.
  3. mercat68
    311
    216
    Mount Airy, MD
    Thanks, but don’t have a torque wrench. I’ve learned over the years to be pretty careful about tightening. Just took it for a test drive, and everything was normal. Noticed a definite difference in the engine not running as much as previously. Also noticed a much more stable charge level (fairly steady number of blue bars, occasional green). No error codes.
  4. mercat68
    311
    216
    Mount Airy, MD
    UPDATE II: Daughter drove car back to school (about 130 miles) yesterday without incident (well, except for the honeybee that flew out of the defroster vents; she managed to shoo it out a window without wrecking).
    padroo and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Sounds like you got it sorted :).
    Glad it worked out(y).
    mercat68 likes this.
  6. Alan BEZ
    Alan BEZ New Member
    Merced Calif.
    You know gentlemen I am in California and own a 280,000 mile 2004 . Last Wednesday the same exact lights came on with me . It was suggested I go to Auto Zone ( a chain auto parts) and they would read the code(s) for me at no charge . After reading this problem and responses I feared the battery pack . But the code that came up was ; inverter cooling system performance .
    That’s when I went to YouTube & got some ideas of what to check . As it turned out my inverter coolant pump had given up .
    I must say I was quite relieved to only pay 40.00 for the part as opposed to 2000.00 for a battery pack . But with the information I have gotten from your exchange has got me putting $ away for the battery pack I will be needing in the future .
    Thank you , Alan BEZ
  7. Phildo
    Phildo Active Member
    140
    110
    Perth, Western Australia
    i-Tech
    It's worth getting a Mini-VCI or VCX cable and Techstream.
    Techstream will go into much better detail than generic diagnostic computers (eg hybrid battery voltages, bad blocks, etc).
  8. mercat68
    311
    216
    Mount Airy, MD
    And thanks to you and others for all the good advice and guidance. This forum is invaluable.
  9. mercat68
    311
    216
    Mount Airy, MD
    Just to update: About 1,500 miles so far on the NewPriusBatteries.com (@2k1Toaster) unit and working flawlessly. Average MPG is as good as it’s been in years (51 vs. 45-48 in past few years). Engine cuts off now sitting at lights (ICE used to run almost constantly). Will update periodically as we put on miles.
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Did you install the battery DIY?
  11. mercat68
    311
    216
    Mount Airy, MD
    Yep. Took better part of the day, but no issues.
    edthefox5 and Raytheeagle like this.
  12. Salamander_King
    11,024
    8,980
    New England
    That's for Gen2? Do you know Gen3 is just as easy?
  13. mercat68
    311
    216
    Mount Airy, MD
    Yeah, a 2007. Have no idea on how much different the remove/replace process is on a Gen 3, but can’t imagine there are major differences. I found a great video on YouTube going through the R&R step-by-step. I’m sure you can find similar for Gen 3.
    Here’s the video for Gen 2:
    edthefox5 and Salamander_King like this.
  14. Salamander_King
    11,024
    8,980
    New England
    Thanks. Not my project, but I was curious for if I had kept my Gen3 long enough. What was the total cost if you don't mind telling us?
  15. mercat68
    311
    216
    Mount Airy, MD
    $1,600, shipping included. It was by far the most cost-effective option.
  16. Salamander_King
    11,024
    8,980
    New England
    Wow, that is a great price. I suspect Gen2 does not have the same problem as Gen3 on the head gasket?
  17. mercat68
    311
    216
    Mount Airy, MD
    Not sure. Only ICE problem we have is burning oil, which I’m told is most likely the rings.
  18. rjparker
    rjparker Tu Humilde Sirviente
    11,144
    6,986
    Texas Hill Country
    I have seen the gen3 battery changed in less than 30 minutes. Straight swap of the whole unit with a new Toyota unit. But the guy had done it many times and was able to take a couple of shortcuts over the factory procedures using some small universal joint socket wrenches. There was some special pin he pulled as well that causes trouble for some. But he was able to use the hv disconnect connector on it.
    Salamander_King likes this.
  19. mercat68
    311
    216
    Mount Airy, MD
    There’s a guy who can top that. Came across this when looking for R&R videos:
  20. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    It's not a race.
    Seriously. Why would you want to see how fast you can go when working on high voltage in your own vehicle?
    That's when you start making poor choices like not using an inch pound torque wrench to tighten the nuts, or not paying attention to routing the wires to avoid chafing.
    Go slow. Give yourself plenty of time.
    Enjoy the process.
    Skibob and Raytheeagle like this.
