Red triangle and yellow exclamation DTC PoA08-264 and POA09-591
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by printone2, Dec 28, 2018.
Tags:
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,737
    Bay Area
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    If they ask nicely, would you :whistle:?
    If you do, my shop with my secluded tool box are yours for the day(y).
    SFO likes this.
  3. NutzAboutBolts
    1,693
    1,737
    Bay Area
    Lol sorry, we only work on family cars since we don’t have any other time for other people’s car, also we don’t want any liability issues. You know how that goes....
  4. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Here is my time lapse
    iPhone ?
  5. Barry CLEMENTS
    Barry CLEMENTS Junior Member
    52
    But, buyer beware. I have purchased two bad ones in the last year.
  6. Barry CLEMENTS
    52
  7. Barry CLEMENTS
    52
    I am wondering if you ever found a solution to your issue. I have the same codes (P0A08-264 and P0A09-591) with a red triangle, low power and very bad mpg. Did you eventually diagnose the problem.
    DinoBravo likes this.
  8. Manfred Vargas
    Manfred Vargas New Member
    Costa Rica
    Hello @printone2 or @Patrick Wong
    A few days ago I made the change of electric motor (converter / inverter) and also I have changed the coolant pump, everything has been fine for a few days, however I have started the p1121 again and within 5 minutes of walking I was They have turned on all the lights, giving the p0a08-264 that I see that you also had that problem, I do not know if you managed to fix it by changing the fusibe # 5, or if you made any other modification and that the vehicle already walks normal without problem ... any help right now would be great.
    The p3108-535 also turned on, which is loss of communication with the control module of the air conditioning system, I have changed the 4-way cable that goes between the car's o2 sensor and the engine and I do not know if that could have been done that code come out, not being the correct cable for the vehicle.
    Thanks for the help
  9. FBZTO
    FBZTO New Member
    Toronto
    I have nearly identical symptoms. Occasionally when it rains I get the beep and red triangle w P0A08-264. I replaced 12v a year ago w Toyota OEM thinking this was problem. Not sure if this was ever solved
