Red Triangle/CEL/Red car with exclamation point on screen
Discussion in 'Gen 2 Prius Main Forum' started by Tboy160, Oct 4, 2018.
  1. Tboy160
    Tboy160 Junior Member
    27
    Flint, MI
    2008 Prius 230,000 just purchased months ago.
    Just drove down Mount Washington, which pushed my traction battery all the way full, almost never happens. Couple hours later while on the expressway, the Red Triangle, CEL, and red car with exclamation point came up, I think I was in cruise control because it hesitated. Seemed to drive fine after. I stop, check oil, coolants and battery (12v) all are good. This is my first long trip in this car. Mileage has been lower than my work commute trips. 48-53 for work. 41-45 on this trip. I attributed the difference being so much more weight.
    AutoZone read codes, but their computer showed nothing. 12v Battery tested good. I am 700 miles from home though. I disconnected the battery to reset codes, they all disappeared. No idea what happened.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    You'll need to find a Toyota Hybrid aware scanner, not all scanners can read hybrids properly.
    In the future you can try additional auto shops or just procure you own device.
    Now you have to wait until the code(s) are thrown again :unsure:
    Raytheeagle likes this.
  3. Tboy160
    27
    Flint, MI
    There is also a yellow ! In a circle with brackets/parenthesis around it. Quick search shows something with brakes.
  4. JC91006
    16,674
    8,519
    How did you check coolant when your car was hot? You need to open the radiator cap, not just look at the reservoir level
    Skibob likes this.
  5. Tboy160
    27
    Flint, MI
    So, that would presume the reservoir isn't functioning properly and low coolant is my issue?
  6. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Not necessarily, you check at the radiator to be sure your system does not have a leak. Under certain conditions the system will leak and the reservoir will be full, even if the radiator is empty. Verifying your coolant level is just making sure that is not your problem. It may well be something else.
    SFO likes this.
  7. Tboy160
    27
    Flint, MI
    Update, read the code, needed coolant pump, easy fix. Around $150.00
