Red triangle/check (actuator problem) engine light battery placed 2016
Discussion in 'Gen 2 Prius Main Forum' started by Kmtomlin, Feb 12, 2019.
  1. Kmtomlin
    Kmtomlin Junior Member
    Austin, Tx
    Hey all!
    2004 Prius/non sks 12v fine
    So the issue I'm have is the red triangle suddenly appeared. In addition, my brake actuator is going out. Pulled the codes and mechanic is replacing it on friday. No battery codes came up.
    Since yesterday I've had the red triangle and a check engine light pop up(in addition to the brake ((!)) And abs lights that were already up from the actuator.
    What could be going on? Hybrid battery was replaced in 2016(before I bought it but I have paperwork) with a one year warranty. 12v is reading fine. What could this possibly be? Any suggestions on things to do?
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Red Flag. Unless it's a genuine new Toyota battery, I'd wager it's a refurbished (expensive sounding word for used) pack that has died (again). You'll need to get the trouble codes read (with a reader capable of reading hybrid codes) as we'd just be guessing till then. Worst case scenario is it's both.
    GOOD LUCK!
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Check the fluids lately? o_O
    Skibob likes this.
