Red Triangle, Check Engine, and (!) pulled Tech Stream codes
Discussion in 'Gen 2 Prius Technical Discussion' started by Gentoo, Nov 14, 2020.
  1. Gentoo
    Gentoo Junior Member
    28
    NY
    Difficulties accelerating on highway, heard a sound on drivers side of the car, after sound check engine, Red Triangle and TPM light came on hybrid battery was at one bar and draining not charging, then speedometer turned off, lost all acceleration at stop light stalled...
    Restarted drove home pulled codes from tech stream codes were p0a0d
    p0a0f
    p3190
    b2795
    b1271.......
    Cleared codes Added Techtron Concentrated to gas tank at 1/2 tank. Cleaned MAF, Clean Throttle Body... Hit it hard on the highway to one exit about 1 to 2 miles accelerated fine up to 70 drove regularly for another 10 minutes scanned with Tech stream to check for pending.. Any ideas
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Which codes (DTCs) did you discover when you "scanned with Tech stream to check for pending" ?
    Here is the workup for DTC P0A0F with INF 204, 205, 533 and 534)
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/0a0f204.pdf
    Raytheeagle likes this.
  3. Gentoo
    28
    NY
    These are the codes I found, I did not notice a pending just active. What does the snowflake icon mean in techstream?
    p0a0d
    p0a0f
    p3190
    b2795
    b1271
    Thank you for the workup
    #3 Gentoo, Nov 15, 2020
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    The snowflake is the icon for "freeze frame" data. That is a snapshot of operating conditions when the code set. It might also contain an "inf" code- or information subcode that can give a more detailed description of the fault.
    Gentoo likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Gentoo likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    It's interesting that you got a P0A0D while sitting in the driver seat. That means the car thought a HV Safety Interlock triggered. That should have a subcode 351 if it happened while the car was running, a 350 subcode if the car was stopped.
    The 2 safety interlocks are the safety switch on the HV battery, and a shorting plug inside the inverter that connects two contacts when the cover is in place. The other option is there was some electrical transient in that circuit that made the car think that happened.
    Gentoo likes this.
  7. Gentoo
    28
    NY
    Funny this is an issue I drove about 2500 miles since I cleaned the Hybrid fan, the Orange tab was not making the contact properly a few months ago I had to fiddle with it, could that have just been a stored code?
