Red triangle, check engine, hybrid warning -- what now?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shameless, Apr 13, 2015.
  1. Shameless
    Shameless Member
    71
    38
    Western Massachusetts
    Hey folks-- I've been utterly thrilled with my 2004 Prius that I've had for about a year. Never a moment's trouble, then today, right when I need it least for several reasons, I've got:
    Red warning triangle
    Orange engine with "Check"
    The car shape with ! on MFD that I believe means hybrid system
    This is clearly not good, particularly since I have to drive home (15 miles), and rely on my car every day. Is this something so severe that I should believe the manual and stop driving immediately? Should I drive home today?
    Any advice on what this might be? I'm going outside now to see if the inverter coolant is rippling. This is all happening 5 days before I leave the country for a vacation, too. What fun!
  2. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Is the cooling fan in the back running on high?
  3. JC91006
    16,933
    8,642
    While you're checking the coolant, make sure you check the oil level too.
  4. Shameless
    Shameless Member
    71
    38
    Thanks! The helpfulness around here is only exceeded by the astonishing speed of replies! I just went out to check inverter coolant -- it appeared to be properly in motion. And now all three lights have gone out. I don't quite get that.
    I will definitely check the fan and the oil, though I'm not sure what you mean by the cooling fan in back. I guess I'm still getting up to speed on all the weirdnesses of this car!
  5. Shameless
    Shameless Member
    71
    38
    For what it's worth, this is the first 70 degree day we've had since, oh, last September or so. Don't know how that might affect inverter.
  6. JC91006
    16,933
    8,642
    I would check the oil level before you start driving the car.......just in case you have to add it
  7. Shameless
    Shameless Member
    71
    38
    Okay, will do. Seems wild to me that one minute I'm having lights that call for heading directly to the mechanic, and the next there's nothing! I mean, I'll take it for sure, but does this tend to point to trouble whose arrival is merely delayed?
  8. JC91006
    16,933
    8,642
    Usually overheating or low oil level can cause what you are experiencing.
