Red Triangle + Check Engine Light on
Discussion in 'Gen 2 Prius Main Forum' started by jqualls, Jan 27, 2017.
  1. jqualls
    jqualls Junior Member
    Colorado
    2007 Prius with 172000 miles. I have lurked around here for several years and have saved a lot of time and money from others good advice but I dont think I have posted here. This problem started around 3 weeks ago when the red triangle and CEL came on while my wife was driving it. OBDII scanner showed p3000 code. On the advise of others I ordered a mini VCI. While I was waiting for it to come in I decided I would try clearing the code and see if it came right back. To my surprise it didn't come back, so I drove around the block and slowly started to drive it on longer drives. We went about 600 miles as a rough guess and then this morning the red triangle, CEL, VSC, (!), and hybrid system light on the touch screen came on all at once. When I parked I shut the car off and then turned it back on, now the red triangle, CEL, and hybrid system light remained on and the VSC/(!) lights went off. I ran by Autozone real quick to see if any codes came up on the OBDII and nothing came up leading me to believe it is a Toyota code or hybrid system code.
    About one or two weeks prior to the first event my wife came out to the car from work and the factory alarm was going off. When she tried to start it the 12V battery was dead. She jumped it from under the hood and everything seemed fine until this started. Besides the codes I have not had any other problems with the car. We replaced the 12V battery around 3-4 years ago. Is the 12v battery a possible cause for all this.
    Checked the inverter fluid and the coolant is swirling. I dont know how much turbulence there should be but it was just a gentle swirl. All other fluids that can be checked by just popping the hood looked ok. The HV battery seems to charge like normal and there has not been any significant drop in MPG.
    Other then the lights the car seems to operate as normal while driving.
    When I get home tonight I can hook up the VCI and get codes.
    Any suggestions or help is appreciated.
    Thanks
    52,849
    certainly worth testing the 12v health. other than that, the codes should lead you in the right direction. at 170k, it could be almost anything. do you keep up with factory maintenance?
  3. jqualls
    Colorado
    Yes keep up with the maintenance pretty well but I do most of it myself. The one thing I havent done that looks like I need to have done that I was reading about today is a brake fluid flush. I bought the care with 60K on it and dont know the service history before that.
    Any thoughts on why the VSC and (!) came on then cleared itself after restarting.
    Thanks
  4. jqualls
    Colorado
    I have about a 40 mile drive back home tonight. Anything that sticks out of why not to drive it tonight. I know it is a do at my own risk but the inverter pump seems to be working and it seems to be driving normal. Outside temps will be between 10-20F.
  5. bisco
    52,849
    no reason i can think of. maybe you have a cell getting low.
  6. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    While we can't say for certain with the information provided, the balance of probability is leaning towards a 12 V battery is in poor health. The big kicker is that you had to jump it. If the battery has had no maintenance over the 3-4 years, the chances are it has had lengthy periods in a low state of charge—a state that lead/acid batteries do not like and is not good for longevity.
    There are plenty of threads here (as you may already know as long time lurker) with the procedure for a rudimentary test to see if the battery is past its prime. The key indicator is at what voltage the battery settles and how long it can hold that voltage with a load of say the headlights on (high) in IG-ON mode (not READY). If it does not settle at a voltage above 11 V and hold it there for several minutes,, the battery should be replaced.
    kenoarto likes this.
  7. jqualls
    Colorado
    Thanks bisco and dolj. I was unable to get the mini VCI driver installed because my computer is 64bit. I was trying to work around it but no success yet so I think I will change the OS or find another cheap computer on ebay. While waiting on that I will test the 12V battery. I was able to hook up my OBDII scanner and pull and advanced code of p3000 but from what I have read that doesnt seem to mean much.
  8. Uvi Blart
    Uvi Blart New Member
    Did you ever figure out what the problem was? I have the exact same warning lights popping up. Originally I thought this had something to do with my oil needing to be changed, but I changed it a couple days ago and the lights came back on today.
  9. bisco
    52,849
    welcome!
    how many miles on her? have you checked to make sure that added oil after draining it? it could be many things, and you need to get the trouble codes read.
  10. brewbear
    brewbear New Member
    2007 prius. Ive had the same issue for about a year red triangle only. The red triangle comes on after 3k miles or so in between oil changes. it clears everytime i replace the oil. I drive about 500-600 miles per week. currently at 199k. i asked two service managers, had the same problem with a few other prius they service in town. couldnt explain it
  11. Jasss
    Jasss Junior Member
    Moreno valley
    Four Touring
  12. bisco
    52,849
    agreed
    Raytheeagle likes this.
