Red Triangle, drives well, but battery at 9.6V - am I on the right track?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chickenboy, Oct 27, 2014.
  1. chickenboy
    chickenboy Junior Member
    16
    Chelmsford, Essex
    there wasn't a warranty - it was over 100k miles at the time, so £1,500 was the quote from Toyota.
  2. JC91006
    16,769
    8,567
    Oh, before the warranty extension. I wonder how this will play out.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    And you felt confident enough to change a cell in the highly dangerous HV battery, yet asked our advice on changing your 12 volt? You also let us offer suggestions about the HHC knowing full well it wouldn't apply if you'd tinkered with the HV battery already. I guess you'll be aware that there is much more to changing an individual cell in the HV battery and if it wasn't correctly balanced that the pack was likely to fail again soon.
    Anyhow, as the Dragons would say; "I'm out"
  4. chickenboy
    16
    Chelmsford, Essex
    Well - thank you Grumpy - certainly living up to your name. i followed advice from here and youtube and it all appeared to work for a year. I needed advice re finding the fault thos time as it appeared to be a different problem.
  5. bisco
    51,950
    a year is decent after replacing a cell. i would do it again.
