Red Triangle Issue
Discussion in 'Generation 1 Prius Discussion' started by hardish, Jan 31, 2014.
  1. hardish
    hardish Junior Member
    2001 Prius
    I have a 2001 Prius with 204K miles. On cold mornings when I start the car first time, within a minute it shuts down with red triangle flashing. After resetting it, car works fine all day without any problem.
    Not sure what is going on. Any help. thanks.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    1) Does this only happen on cold mornings?
    2) Have you checked the voltage of the 12V battery both sitting (no pwr) and IG On (engine not running)
    3) When you reset it, does the triangle go away?
    4) Are there any other lights?
    5) Do you have a Prius aware code reader?
  3. AlexY
    AlexY Member
    163
    45
    UK
    Sounds exactly the same as my prius problem, throttle cleaner solved it.
  4. JC91006
    16,933
    8,642
    Interesting a dirty throttle would shut down the car and trigger the red triangle. It must have been really dirty with carbon deposits?
  5. Patrick Wong
    18,210
    6,517
    The dirty throttle body/throttle plate issue is particularly significant with Classic; less so with 2G. That will cause DTC P3191 (engine no-start).
  6. JC91006
    16,933
    8,642
    I like it...a $5.00 fix in a can
  7. hardish
    2001 Prius
    1) Yes only noticed on cold mornings. 2) I will check the voltage later. 3) Yes triangle goes away after resetting it. Car runs fine with no problem until next morning. 4) No other lights on. 5) No don't have Prius code reader. I did go to Autozone and they hooked up the computer. I got the codes.
  8. hardish
    2001 Prius
  9. hardish
    2001 Prius
    Yesterday morning car started fine and no red triangle. I checked the display and it showed outside temp 36.
