Red triangle light flashed today
Discussion in 'Gen 2 Prius Technical Discussion' started by Stephanie Villarreal, Jan 24, 2019.
  1. Stephanie Villarreal
    Stephanie Villarreal Junior Member
    southern california
    Hi! I have a 2007 Prius, we are the original owners, have had it from new. She's got 199,750 miles on, and I just replaced the 12V battery Tuesday because it finally died. So yesterday on the way home from work, and again this morning on the way to work, the Red Triangle light blinked on for 3-5 seconds, then shut off. Both times i was braking, but not hard, just a regular slowing of the car due to traffic.
    No other lights have come on, and the car is not acting weird in any way, except for the triangle light. I've got about 500 miles to go til my next oil change, no other maintenance is due or anything that I can think of. Please help! Is my baby going to give up her little Barcelona Red ghost?
  2. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    It’s low on oil. Probably 2.5 to 3 qts. Definitely fill it up before you drive anymore.
  3. Stephanie Villarreal
    southern california
    Why would it be low on oil? I haven't seen any leaks and we get it changed regularly..
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Matt is almost certainly right. Just humor us and spend the few seconds it takes to check it. ;)
    All engines use oil. It's how they lubricate the rings and cylinders. New ones use very little. As they age and wear, they use more and more. With that many miles, you should be checking the oil at every gas fill up unless you know you can go longer. Now that you've let it get low enough to trigger a warning light, assuming that is what triggered it which seems most likely, there has been increased wear due to lack of lubrication and it will probably burn oil faster.
    Skibob likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Because of a design flaw by Toyota, where the piston rings and drain holes eventually get coked up and allow oil to pass.
    This affects many models (and other brands) also.
    Check your engine oil via the dipstick on a level surface after it has sat for awhile, or overnight.
    Skibob likes this.
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I agree. The car is low on oil. Do not start or drive the car until you check the oil. You have already done some damage to the engine but if you continue your gonna throw a piston.
  7. Stephanie Villarreal
    southern california
    Thank you for the explanations. I took the car to the oil change place at lunch and the oil WAS low. They changed the oil for me, and we'll be checking it in a week, and regularly after that. The mechanic said we can change to a thicker oil (higher viscosity?) if it continues to be a problem. Will that help or should I just plan on retiring old Barcelona and choose a newer model?
    jerrymildred likes this.
  8. bisco
    52,674
    time to move on, all the best!(y)
  9. Skibob
    2,912
    1,505
    Northern California
    Oil use is very common with these cars. You should easily get many more miles out of the car. Unlike most other Toyota’s you just have to check the oil once in a wile
    oldtechaa likes this.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    and Bisco, really? You're better than this....
    Seriously? Burning 2 or so quarts in 4500 miles is being considered to be a problem? I must be in the twilight zone or something....
    8 bucks worth of oil every 2 or three months makes it a crisis worth getting a new car? How about just doing a basic check of the oil dipstick once a week and add a bit if needed. Hell, even I check my oil almost every time I fill my gas tank. It's not complicated......just because the car has a 5k mile oil change interval DOES NOT mean you don't have to check it or maintain it.
    Someone is putting some serious BS into your heads about needing to replace an engine or car just because of some oil usage....welcome to the world of ICE lubrication...
    Raytheeagle and Skibob like this.
  11. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Because it's a mechanical device. Because it's an internal combustion engine and NO engine, regardless of how new or old, consumes ZERO oil. Anyone who says otherwise has a false understanding of how lubrication systems work. The chances of an engine consuming ZERO oil is the same as finding a perpetual energy machine. Obviously, a new engine should have very low consumption and older engines, as components experience wear, will typically see more consumption. That's life. That's every ICE on the planet.
    GrGramps and Skibob like this.
  12. Skibob
    2,912
    1,505
    Northern California
    If I may play devils advocate, I have owned many Toyota’s over the years, I currently own 4. The only other Toyota I have ever had an oil problem with was my 1993 Camry. And that problem was it had a bad oil pump seal after 310,000 miles. I think people get into the mindset of never having to check the oil because you get spoiled by the reliability.
    That being said I always check all my cars every now and again. Just because I’m from the old school I guess.
    #12 Skibob, Jan 25, 2019
    Raytheeagle and jerrymildred like this.
  13. Ernest Erickson
    Ernest Erickson New Member
    16
    Arizona
    Technology
    Depending on climate, and average temperature, a higher viscosity would probably work well.
    I use 'heavier' oil on high mileage engines, due to normal wear, and heat also plays a part as well.
    Always check the oil often...and if you can, obtain an oil plug that has a magnet in it, to trap ferrous debris floating in the oil.
    If it was not designed to be in the crankcase, it should never be found in the oil, no matter how small...
  14. jerrymildred
    11,517
    14,164
    Tampa, FL
    Good job! I don't think you have anything to worry about. Just keep a close eye on the dipstick till you get a feel for the rate of oil consumption. Then you can adjust your check intervals accordingly.
    Over the decades, I've never bought a new car and I've never owned an "oil burner." I think there was one that sometimes needed the oil topped off between changes. I like to change the oil more often than the maintenance schedule specifies, and I think that that relative reduction in combustion contamination in the oil reduces wear. But then again, I've never taken a car past about 175,000 miles. The more miles, the more wear and the oil burning that results.
    So, good job getting to 200k. Don't stop there unless you just "HAVE" to get something new and exciting.
  15. Stephanie Villarreal
    southern california
    again,and thank you all! We are keeping her, I love her too much to retire her. Since she's close to 200K, we're thinking of replacing the hybrid battery and rebuilding the engine, which should get us at least a few more years with her. If I take her to a dealership it will cost quite a bit. Do you have recommendations for looking for a reputable repair shop in the Los Angeles area? I've found 3 listed, and I'll be checking their records with the BBB.
  16. Skibob
    2,912
    1,505
    Northern California
    I would hold off on either until you have a problem. Generally it’s cheaper to get a used engine than rebuild one, plus your engine might have over 100,000 miles left in it. The oil burning is not from worn rings, it’s from a bad design. There are threads here that discuss unsticking the rings. Check them out.
  17. jerrymildred
    11,517
    14,164
    Tampa, FL
    Good idea to do your research and be prepared, but I agree with @Skibob that it would be wise to wait till you really need to before replacing expensive stuff. Just try to be ready. A used engine with fairly low miles would be my first choice when the time comes if I planned to keep the car.
    Skibob likes this.
  18. Skibob
    2,912
    1,505
    Northern California
    200,000 miles? It’s practically a spring chicken around here. ;)
