red triangle no info
Discussion in 'Generation 1 Prius Discussion' started by Unseen, Apr 27, 2019.
  1. Unseen
    Unseen New Member
    Santa Rosa
    2003 Prius
    I
    I have 2003 Gen 1 Prius with 198,000 miles. last week the red triangle appeared and the cooling fans in the trunk kicked on. I checked the coolant level in the inverter tank (it was a little low but not below the low level).
    The coolant was cavitating which from I read means the pump is working. I plugged in a generic code reader and the only code I get is P3014 with no information. I reset codes, and drove the car in morning for 5 minutes and it ran great and the triangle did not reappear, i drove it in the heat of the afternoon and it came back on after 10 min. Any ideas? Do i spend the money on a inverter pump and coolant or is this something else?
    Cheers,
    Mike
  2. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    A search on here for P 3014 leads me to think that bank 4 of HV battery is bad or has corroded connections, needs cleaning or replacing
    Unseen likes this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Google search P3014 prius
    You will find that it is Block 4 becomes weak.
    So the problem is in the hybrid battery.
    Could be corroded wiring, could be a failed module.
    If you are doing the work yourself you could open it up and pinpoint the exact problem to be sure.
    Given the age of the vehicle a failing hybrid battery could be expected. Will cost a couple thousand or so t properly fix it with New cells.
    Everything else is Used cells.
    Unseen likes this.
  4. Krisstroll
    Krisstroll New Member
    France
    hello everybody , I m new on the forum, back in Europe (France) , and not much of people who knows something about working on a prius here, i am trying to solve a pbm :
    prius 2 ; august 2006 ; 192000 KM , used when bought , Tranny maintenance ? 12 V battery fully charged every time i try to start but used
    i had a HT battery failure, bill from toyota that i refused (2500 €), i change my self the 2 faulty elements (thanks you tube) and put back everything : 212 V on testing
    when i brought my prius 2 back home the thermic was working D & R but of course electric was not working.
    since then , and I checked and rechecked everything, the orange big security plug position (as mentioned by several personns) all the 3 connectors to the ECU, the connector to the Fan , even the polarity of the HT connectors ....
    same old song : THE READY MODE DOESN T COME ON, NO D OR R POSITION POSSIBILITY, THE THERMIC DOESN T FIRE UP , I noticed that i don't hear the Clac Clac of relays ans that the 12 V battery is drained after 1 day if stays connected. NO error CODE on ODB device
    i desinstalled one of the 2 main relay to try to test it, but i am stucked
    any ideas ? any suggestions, HEEEEEELP PLEAAASSSE
    thanks
