REd Triangle of Death - but no problems or codes?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Soldridge, Mar 25, 2015.
  1. Paul Soldridge
    Paul Soldridge Junior Member
    43
    coplay pa
    2005 with 123,000 miles. I have owned for a few thousand miles. Car was dealer maintained at every recommended interval. Car runs perfect.
    After car sat for a week or so, I drove it and the red triangle popped up along with PROBLEM statement and take to immediately to dealer symbol. Red Triangle and other warnings repeats every once in awhile - will go a day without, and then will come on and off within a couple miles. Car continues to run fine. There are no other check engine lights. I have checked all the fluids and they are fine. The battery charges fine, and holds the charge overnight. I have a generic code reader and there are no codes. I have read other posts, and there are always problems that seem to come with the Triangle. Gas mileage is fine as well.
    Any suggestions on what to try next?
    52,863
    how is the 12 volt? you may need a toyota specific code reader.
  3. Paul Soldridge
    43
    coplay pa
    I thought about the 12 volt but didn't check it yet. Car starts fine. I will have to check records if it was replaced
    52,863
    it's a funny thing, how the car can start, yet the voltage fluctuations can create havoc with the computers. if not starting were the first symptom, 12v evaluation would be much simpler.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    You say you checked all fluids, but just to be sure, the oil level is OK? Did you look inside the inverter coolant tank for movement, indicating the inverter coolant pump is working?
  6. Paul Soldridge
    43
    coplay pa
    Oil was perfect. Checked twice as I saw that is a common culprit
  7. Paul Soldridge
    43
    coplay pa
    Inverter coolant pump? Where is that located. The triangle has come on when relatively cold and hot
  8. bisco
    52,863
    under the hood, against the fire wall, is the coolant tank. it's in the manual. there should be turbulence inside the reservoir when the car is made 'ready'.
  9. bisco
    52,863
    has the car had all the recalls completed?
  10. Paul Soldridge
    43
    coplay pa
    I will check the coolant tank tomorrow and yes all recalls done.
  11. bisco
    52,863
    get a digital volt meter, 10 bucks. in the morning, before turning on the car, open the passenger door, lean over and pop the hood. inside the fuse box is a jump point for the 12 volt. it should read 12.5 volts or better.
  12. Paul Soldridge
    43
    coplay pa
    I will do this test - why open the passenger door and pop the hood?
  13. bisco
    52,863
    if you open the drivers door, it activates the brake accumulator and other electronics, which reduce the voltage reading. you can also leave the hood popped the night before, or go straight to the battery, but that requires a bit more work.
  14. Kevin06prius
    Kevin06prius Junior Member
    45
    Westchester
    Something similar happend to me yesterday. I have an 06 with 160k and the red triangle came on for the first time yesterday and the word "problem" comes on the Nav screen. It only stays on for a few seconds and then goes off. I think I have seen a pattern of it coming on while on curves on the highway at higher speeds but I'm not sure.
  15. bisco
    52,863
    check your oil level.
    Kevin06prius likes this.
  16. Paul Soldridge
    43
    coplay pa
    Drove mine to work today - 15 miles and no triangle! I am going to try the battery test Saturday morning.
  17. bisco
    52,863
    another thing to check is the battery connections. at the posts, and especially the negative to body ground. a loose or corroded connection can cause computer problems.
  18. Mendel Leisk
    42,355
    That's easier said than done. Any typical male will go hunting for a $10 meter, but then the little nagging voices start, and next thing you know... Anyway, you end up with a really kick nice person meter. ;)
  19. bisco
    52,863
    may it serve you well, for many years to come.:)
  20. Mendel Leisk
    42,355
    Yup, well: I need it, gotta sort out the dud AA batteries every so often. :ROFLMAO:
