Red triangle of death with no codes
Discussion in 'Generation 1 Prius Discussion' started by BoNosAll, Nov 14, 2013.
  1. BoNosAll
    BoNosAll Junior Member
    I just acquired our second Prius, a beautiful 2002 (Gen1 in the USA) with 90k miles. On the dash, I get the red triangle of death with the exclamation point inside it. On the computer info screen, I have an icon of a car with an exclamation point in it and it reads "problem". I have connected the OBDII reader to it and it does not have any codes. Nothing in the history, or in the current or pending. The car has full power and runs fine, but has the stupid RTOD. How can I check to see what the icon means, and how do I get rid of it?
    My other prius is a 2006 (gen2).
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    You need a Prius aware scanner. There is obviously a code there or the triangle would not show up. Or you could take it to the dealer but first, is the car running fine?
  3. BoNosAll
    The car seems to be running just fine. No issues going normal speeds, braking is fine, everything seems to be good. Except the stupid warning symbol.
  4. amitt
    amitt Junior Member
    53
    2002 Prius
    I
    the first easiest thing to check is the inverter pump, it can cause inverter high temp and this message, the car can drive this way as you described.
    Put your hand on the pump to feel if it's running, or look at the inverter coolant filling tank, you should see some coolant circulation there.
    yotatoter likes this.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Ok, well as amitt described, pls check to see if your inverter coolant pump is working. Turn the car to IG On (doesn't matter if its started but past ACC). Open the lid to the inverter reservoir and look for circulation. If none then your problem is the inverter coolant. If circulation, then you have 2 choices.
    1) Take to the dealer to have the codes read (don't have them do any service just post the codes here, we've had too many dealers rip people off)
    2) Reset the codes by momentarily disconnecting the neg lead of the 12V battery and see if the codes come back
    There's also a possibility you could have a catalytic conv. problem or other problem. I would recommend option 1 b/c you want to have peace of mind and if you never know what the codes were, you'll always have that doubt in the back of your mind.
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    This is a long shot, but I had that same problem after a service job on my '07 and it was the air filter housing. The tech did not seat it correctly after the service and there was a slight vacuum leak...
  7. BoNosAll
    Okay. Here is the skivy. I took it to the shop and they ran the scanner on it. I was actually hoping for the power steering unit as the sevice manager told me that is what is most often the case on this car. There is also a a warranty extension on that until the end of 2013. Well, that was not my luck. The problem they found was, the trunk seal was bad. It caused water to fill up the trunk sometime in the past. I am not sure if the PO knew about it or not, I am thinking they did. Anyway, the service manager said the trunk filled with water and shorted out the module, battery and a few other items. They said it would be about $4600. I think I will rebuild the batteries myself. I am not sure if the module is bad, or if they just want to take my money. Has anyone had this happen to their Prius? I just bought the car for $4500 and I can't see putting another $4500 into it. It is in excellent shape and only has 89k miles.
  8. BoNosAll
    Who is the best at converting the gen1 battery over to gen3 cells? If I am going to convert it over, I might as well do an upgrade at the same time. Are the modules on the battery interchangeable, or will I need to have the new one reprogrammed?
  9. Patrick Wong
    18,210
    6,517
    Although it is possible that the trunk rubber seal needs to be replaced, I think it is more likely that the car was parked in an area where it flooded. When you remove the hatch trim and open up the battery case, you can see the full extent of the problem. Also look at the 12V battery and spare tire locations.
    I suggest you obtain the DTC that were logged by the traction battery ECU.
    No programming is needed. You may discover physical fit issues when you install G3 modules, but that would be the best long-term solution. Good luck.
  10. bwilson4web
    16,523
    First get your own, Prius-aware scanner. You can swap everything in the car and still have it fail. As for the traction battery 'scan', I'm not impressed.
    • Do you see water in the spare tire area?
    • Do you see or detect water in the body areas on either side of the trunk?
    As for rebuilding the traction battery, it is not that hard. Just pay attention to details and the rest is easy.
  11. BoNosAll
    I will get the car back from the shop on Monday. I will check all of this out. The car has been a pacific northwest car for it's whole life. We rain alot here, but almost never flood. It is possible though. As most batteries can be submerged in water for a short time and not be ruined, I am skeptical about the batteries being dead. Especially in that the battery meter on the display screen shows them as fully charged and it runs on both the battery (silent) and gas motors. I am hoping I can fix it with just a battery ECU change.
    I have a regular obd2 scanner that has worked good up until now. I have also used my laptop to run codes on a BMW I had. Which scanner is best for these cars? I have read a few other posts and feel the windows software with the prius interface may be the way to go. What do you all suggest?
    Bob, I have read your posts and watched a few videos on replacing the cells. It does not look too difficult. I am fairly confident I can do it. Is there a good location to get gen3 batteries to replace the gen1 cells? Anything special I should look for?
  12. bwilson4web
    16,523
    I've grown fonder of the miniVCI because the hacked Techstream provides everything known about the Prius.
    As for getting modules, it is a dynamic market and I really don't have any contacts on the West coast.
    GOOD LUCK!
  13. BoNosAll
    Sounds good. I have an USB to obd2 cable that I used for my BMW. Any chance it will work and I only need the software? I have seen the setup at several locations, where do we get the "hacked" techstream software?
  14. bwilson4web
    16,523
    I don't know if it would work. As for getting a copy, mine came with the miniVCI.
  15. BoNosAll
    Sounds good. I will pick one up. Are there sponsors on the site that we should support?
  16. BoNosAll
    I just got back from the dealer and the three items they say are in need of repair/replace are: HV battery, computer and junction block. I purchased a new trunk seal to make sure that really is not the issue. I am hoping that removing the carpets in the trunk and putting a heater/fan in the trunk will dry things out and keep me from having to replace the batteries. I doubt it will fix it though. I have ordered the miniVCI, and hope that will allow me to reset the codes and things once dry. Thank you all for you input and help.
  17. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    I am not sure ,but I doubt that those items listed are even bad..first off,if the hv computer were bad i do not think it will read battery status on the dash and second I do not believe the care will run.. Do NOT know this for a fact,just speculating. Now with that being said I have seen it throw the p3009 code because of moisture in the battery pack. It did not indicate the battery is bad ,however it can be caused by ACID or moisture leaking from battery and grounding it to the battery box.. Let us know what you find..
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm telling you Bo, if it were me in your shoes, and the car really runs fine and gets good mpg, I would not have the dealer touch it. Do you still have the triange and CEL? Is it still running fine? getting good mpg? Is the trunk actually wet?
    If so, I would be very curious to see what the code is.
  19. BoNosAll
    There was water in the trunk. They told me the trunk seal was bad and rain leaked in and flooded the batteries. I am skeptical about that, but figured whatever. I ordered a new seal from the dealer and took both the car and the seal home. I looked at the old one and it looked just fine. I decided to do the old get in the trunk and have someone spray the trunk area with a hose. It leaks at the top of the trunk. I looked closely at the car and the trunk does not sit all the way down at the top. I think I just need to have that adjusted. Hopefully that will be all it requires to fix the water issue.
    I am not sure about the batteries. The dash still has the triangle warning symbol. It seems to run fine, but I have not driven it more than 10 miles or so. I will take it out on the road this week. The battery looks like it is charged on the display, but who knows if that is correct. The gas motor turns on and off and the car runs great. It actually has more power than my 2006 Gen2. I have ordered a miniVCI and will run the codes when it comes.
    bwilson4web likes this.
  20. BoNosAll
    Update. My nice new MiniVCI just arrived and I hurried to run the codes. It looks like it is throwing codes P3000 and P3009. Looks like battery leak and hv control unit. I am assuming the ecu for the battery is bad and at least a cell or two is defective. Does that make sense? The dealership who ran the codes before said I needed to replace the hv batteries, the battery ecu and a junction block. I assume the junction block is a fuze block or something similar that is close to the ecu.
