Red triangle of death with vsc and tpi. No check engine.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mavi, Oct 12, 2015.
  1. RizwanJaved
    RizwanJaved New Member
    17
    Michigan
    Thank you!
    I went to the dealership and they said the entire unit needs to be replaced. They opened the hood and pointed to the electric stuff next to the engine. The one with the silver cover that says hybrid synergy or something. Dealership said that whole thing needs to be replaced. Is that where the transmission is or is that just the electric motor itself? I’m still averaging over 50 mpg so I find it hard to believe that the electric motor needs to be replaced, unless transmission is a part of it because of the hybrid setup.
  2. Patrick Wong
    18,210
    6,510
    The inverter has the silver cover. The transaxle (which contains the two motor generator units and needs to be replaced) is under the inverter. DTC P0A2B points to a fault with a motor temperature sensor within the transaxle. The repair philosophy is to replace the transaxle as the sensor is not separately available.
    I suggest you have a used transaxle installed if you intend to keep the car.
  3. RizwanJaved
    17
    Michigan
    Yes, I do intend to keep the car. The Toyota dealership quoted me at $7500 for this job on top of the $350 inspection fee. My 04 is barely worth 4K considering how old it is so there’s no way I’m willing to spend over $1000-1500. Junk yard transaxles are going for $100 for high mileage and about 400-500 for low mileage. I’ll get one of those and have my mechanic do the installation.
    Thanks a lot for the help. This is my first time in a car forum and it’s an amazing resource.
    Dxta and Raytheeagle like this.
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    1. What's the condition of your transmission fluid? Has it bring changed before?
    2. If you have replaced it before, this problem points you to the transmission.
    3. Is your inverter water pump too OK?
  5. RizwanJaved
    17
    Michigan
    I have never changed transmission fluid before. I got the car 11 months ago. I don’t know the condition of my inverter water pump, but the dealership did say that I have a recall on a water pump. I’m not sure if it’s the same thing you’re talking about.
  6. bisco
    51,933
    how many miles on her?
  7. RizwanJaved
    17
    Michigan
    Just 112,000
  8. RizwanJaved
    17
    Michigan
    Update: after putting about 50 miles with the lights on. My car wouldn’t accelerate anymore while driving at about 45 mph. I pulled into a plaza as the car was slowing down and now I’m waiting for a tow truck.
  9. Patrick Wong
    18,210
    6,510
    Try disconnecting the 12V battery to clear the fault code, to see if the car can be driven again. This is a temporary measure only.
  10. RizwanJaved
    17
    Michigan
    I haven’t disconnected the battery but I did start it and tried to move it. The car is moving at about 1-3 mph and it’s shaking violently so I stopped. Does this sound like a transmission issue?
  11. Patrick Wong
    18,210
    6,510
    Yes
  12. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    If you got a scan tool, rescanned it again for codes.
    Any transmission codes now, means you got to be prepared to get the transmission replaced.
  13. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    After a few weeks my transmission just wouldn't work anymore. I had sourced a company with a junkyard to install a transmission from a 80k prius for 1.2k, and that fixed my problem. Honestly for most prius at this point, i'd just junk the car and move on. The battery may fail next, as well as many other expensive issues that on top of a oil consuming engine is just too much sunk cost.
