Red triangle of death won't disappear after new 12V battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ben Pidder, Sep 3, 2023.
  1. Ben Pidder
    Ben Pidder New Member
    netherlands
    Active
    Electricity kept falling away and coming up again when the car was not 'on', until I noticed that it always came back on when touching the minus-pole of the battery. After I attached the cable from the negative pole to another point at the car body, electricity has been stable. I am not sure if the problem then was due to a rusty body or a bad connection of the cable at the old point.
  2. JohnPrius3005
    JohnPrius3005 Active Member
    419
    227
    California and Hawaii
    Hi Ben,
    You got lucky! Battery connections are always critical. There is a lot to learn about Priuses. Good luck with that process. Accept all the luck you can get, happily.
