Red Triangle of Death
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nickkliesen, Mar 31, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Thanks, @Texas Hybrid Batteries and @dolj. I made a comment on that other thread with a link here to your comments.
  2. Manjot Sandhu
    Manjot Sandhu Junior Member
    17
    Seattle, WA
    Just get a used battery all of them will start coming on till you dont replace it, no point of fixing anything just get the battery used ones can be around 1000-1500
  3. Nickkliesen
    Nickkliesen Junior Member
    26
    Brooksville, Florida
    Its alive again finally but I have one last question. My key fob is not working i have changed the battery in it it will start the car but it will not lock and unlock. this is the spare key as the regular key has disappeared. I am not sure if it ever worked before or not but my questions is can the battery of the car being unplugged for so long cause it to not recognize the key fob?
    52,789
    no, it's probably not an original fob.
  5. jerrymildred
    11,517
    14,167
    Tampa, FL
    Congrats!! How many cells did it take?
    I think there are threads here about programming the fob. It's a seriously goofy process, imho. ;)
  6. Nickkliesen
    26
    Jerry, ended up needing a total of 6 but one had to be replaced more than once it went bad after I had it grid charged.
    jerrymildred likes this.
  7. Nickkliesen
    26
    It is the original fob but it looks like it may have gotten wet the rubber around the buttons is all chewed up
  8. jerrymildred
    11,517
    14,167
    Tampa, FL
    Here are a couple fob possibilities if you can't get the old one to work. There are others, too.
  9. Nickkliesen
    26
    Thanks Jerry
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
    You might get one cheaper from Todd and he can help program it.
    Brian in Tucson likes this.
  11. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    If you are referring to what has been dubbed "The Chicken Dance", then it is not an option. You need to have a working key fob in order to add a new key fob using the chicken dance routine.
    A visit to the dealer is probably the only option to reinstate the SKS functions.
  12. Nickkliesen
    26
    I don't have a smart key system so no chicken dance for me
