Red Triangle of Death
Discussion in 'Generation 1 Prius Discussion' started by IAN HIGGINS, Dec 8, 2021.
  1. IAN HIGGINS
    IAN HIGGINS New Member
    Bahia de Los Angeles, Baja California, Mexico
    2002 Prius
    Any information would be much appreciated. I have a 2002 prius with 208000. Still get's good mpg, seems to run great. I replaced the HV battery with a few months ago.
    About 2-3 times a month the red triangle will come on. I pull over, turn the car off and on and it drives fine again for a while. I've scanned the OBDII and it says no codes in the ECU.
    Any tips?
    52,682
    are you scanning with tech stream?
  3. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    A typical OBDII scanner will only pull codes associated with the check engine light (generic codes). You'll need to get access to a more powerful scanner. Techstream is the official Toyota stuff, and if you search this site you'll find ways of getting it cheap. But there are also other scanners that will pull the Toyota & hybrid system codes.
    Until you have those codes, there's no way to know where to start.
  4. Dirty Jim
    Dirty Jim New Member
    Nashville
    Here we go again...
    Load test your 12v battery then report back.
  5. IAN HIGGINS
    2002 Prius
    I'm scanning with the dr. Prius app. and a Bafx obdii scanner.
  6. IAN HIGGINS
    2002 Prius
    Will do. Thanks for the info.
