Red Triangle, Orange Brake, VSC, Engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusOwner113, Sep 8, 2017.
  1. PriusOwner113
    PriusOwner113 Junior Member
    Westfield, NJ 07090,USA
    What is causing this? Are there any reputable Toyota service departments in Union County New Jersey, USA? Why does Autozone engine code checker unable to pick up any problem codes on my car? If anyone has any experience with this, please let me know.
    Thank you!
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    Autozone's checker cannot pick up Toyota's Prius-specific codes. The dealer scanner software can do that.
    If you post the codes from the dealer, users here can help guide you further.
    Raytheeagle likes this.
  3. PriusOwner113
    Local dealer is charging 130 to check the codes. It seems more than a bit excessive. Is that the going rate. Is there a dealer near me wo does not charge
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Look for area hybrid specialists; usually cheaper. You can also get your own to use with a smartphone for just a few bucks but that will take a few days shipping. I don't use those so I'll let others recommend specifics.
  5. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Return your AutoZone code checker
    I use a $79 UScan code checker from Pep Boys I returned it and got the one I could fun on my smart phone. Everybody on the forum like the Techstream laptop software
    I think they may be in New Jersey
    For the United States:
    Call (800) 228-7667
    Email [email protected].
    iPhone ?
  6. Paul Schenck
    524
    307
    Fresno, California
    #6 Paul Schenck, Sep 8, 2017
  7. Paul Schenck
    524
    307
    Fresno, California
    All of those codes just mean one or more cells in your high voltage battery have failed.
    iPhone ?
    PriusOwner113 likes this.
  8. PriusOwner113
  9. Paul Schenck
    524
    307
    Fresno, California
    Your 12volt battery appears to be working well as it is successfully started your hybrid system and reported trouble. It is not your primary problem.
    iPhone ?
  10. Paul Schenck
    524
    307
    Fresno, California
    Have you found a Code reader yet?
    iPhone ?
  11. ChapmanF
    19,020
    Well, one of the images above showed a C1259. That is nothing but a code stored in the braking computer to note that it has been told of some problem by the hybrid-vehicle computer. You don't get the rest of the story without querying for the exact codes stored in the HV computer—and it watches out for many, many possible problems besides failing battery modules.
    If there were only one thing that every problem in a Prius ever turned out to be, the list of diagnostic codes would have one entry.
    -Chap
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    What we are trying to say is that without the trouble codes from the car telling what has failed, we are unable to intelligently assist further.
    Paul Schenck and Raytheeagle like this.
