Red triangle question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dummy, Aug 16, 2019.
Tags:
  1. Dummy
    Dummy Member
    121
    23
    Colorado
    2005 Prius bought in March. It had 150k and now has 175k. The previous owner said the hybrid battery hasn’t been replaced. The car was in great condition and obviously maintained well.
    Yesterday I went into Wal-Mart for about 20 minutes. Then I started the car and put it in D. I got the Red Triangle and a warning on the screen saying to push the park button because the battery wouldn’t charge in neutral. The battery gauge showed two red bars and it drove around the parking lot just fine (except the red triangle). I shut it off for a few minutes and then turned it back on and switched off the A/C and unplugged the phone charger. It hasn’t come back on yet. Should I be concerned?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Your traction battery is most likely in the beginning stages of failure. Plenty of information around here about it. Get a Toyota capable OBD scanner to start, like a mini VCI and techstream. It will prove useful later on. Plus unless you disconnected the 12v battery there will be codes logged. They would be useful in figuring out why the red triangle came on
    52,861
    i wouldn't be too concerned. just put $1,600. away for a new battery when necessary, and you'll be good to go
    Skibob likes this.
  4. ChapmanF
    19,027
    I can see the "put it in D" ... then the car saying to push park because it can't charge in neutral ... then driving around the parking lot (which implies not being in neutral).
    Are there any further details in the story pertinent to that middle part where the car believed it was in neutral?
    Skibob likes this.
  5. Dummy
    Dummy Member
    121
    23
    Colorado
    I was in D creeping around the parking lot. I thought it was weird that the message indicated it was in neutral when I was driving it around the lot. I can’t explain it.
    I have a Bluetooth OBD2 adapter and checked for codes using my iPhone OBD fusion app. It didn’t show any codes.
    It was 95 degrees at the time. Could that have anything to do with it?
    Buzzkill is what you is...
    #5 Dummy, Aug 16, 2019
  6. Skibob
    2,912
    1,505
    Northern California
    This is Prius Chat. Do you really expect that much information? :whistle:
    Plus the guys name here is Dummy. Just sayin.
    (I actually give him props for the name.)
    #6 Skibob, Aug 16, 2019
  7. ChapmanF
    19,027
    I've seen threads here where the grease in somebody's shift selector got kind of old and gummy, and the selector didn't always spring smartly back to the "I'm not selecting anything right now" position, and was giving the ECU confusing signals.
  8. Patrick Wong
    18,210
    6,522
    A common failure on the gear selector is that the plastic binds up and causes the selector to stick in the D position or R position. A related possibility is that it is necessary to hold the gear selector in the D position to get the car to move forward.
    I had not heard of a problem where the system thinks that the transaxle is in N while the car actually can move forward.
    How to Replace 2G Gearshift Lever | PriusChat
    In the OP's case I think s/he should ensure the 12V battery is fully-charged and the battery cables are secure.
    SFO likes this.
  9. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    Was your driver's side door closed all the way? If the driver's side door isn't latched completely or open while in drive, you will get this exact same message with the Red Triangle of Death. Went out and replicated it just now in my Gen 2 Prius. No worries, your Prius is likely fine.
    #9 TheLastMojojomo, Aug 18, 2019
    SFO likes this.
  10. Dummy
    Dummy Member
    121
    23
    Colorado
    That is absolutely possible. I’m also thinking it is possible that I moved the shift lever too slowly (kinda like the scenario mentioned above).
