Red triangle, VSC, and !
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RedRedRed, May 24, 2019.
  1. RedRedRed
    RedRedRed Junior Member
    25
    Los Angeles, CA, USA
    Was on the highway and the red triangle, VSC and circled explanation lights came on. Had enough time to get off the highway before I lost power.
    Now when I try to start I get this...
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    The owners manual can tell you what each one of the those icons means.
    You will need to read the OBD2 codes (DTCs) and post them here for further help.
    Raytheeagle likes this.
  3. JC91006
    16,930
    8,639
    If your car died while you were driving it, there's a high possibility you have a failed inverter pump
  4. RedRedRed
    25
    I’m hoping that’s it. Dreading it is the hybrid battery.
  5. RedRedRed
    25
    I ran out of gas last year and that was a similar experience to what happened yesterday. Is there a way the sensor in the gas tank could be off? My gauge showed a quarter tank.
  6. bisco
    52,752
    yes, there is a bladder in the tank which can cause gauge problems. put at least 3 gallons in to test it.
  7. JC91006
    16,930
    8,639
    Running out of gas would get you the same results. Make sure you put at least 3 gallons in your car to start it
