Red Triangle VSC, ETC Engine Codes: P0010 - Powertrain, P1121 - Powertrain, P0A80 - Powertrain
Discussion in 'Gen 2 Prius Technical Discussion' started by comatoes, Oct 14, 2023.
  1. comatoes
    comatoes #GreenLife
    288
    17
    2007 Gen II Toyota Prius 203,000 miles.
    So the red triangle and VSC and check engine lights on my car recently came on. A few months ago before the lights came on I noticed that on some days I would start my car and drive up a hill and the battery would go all the way down to one bar. It would slowly recharge and be green for the rest of the trip. Now, as is the title, I get those error codes along with red triangle and VSC lights. I've driven it a few times after the errors and my mpg dropped from 46mpg to about 40mpg. I have kept the 12 volt on a battery tender for the past month and the error codes still are listed. I drove the car today and before I parked it the Hybrid battery showed full green. I just went and started the car after sitting for about 6 hours and the hybrid battery is still full. The car idled before I shut it off.
    Does anyone know a cause?
    What will it take to fix it?
    Further Troubleshooting?
    Can I just drive it or do I risk more damage?
    Thank for your help.
    Edit 1: I just had a thought: I had done the "stealth" music head unit install and I had seen the lights come on the dash when I was working on that but eventually checking my wiring had made the errors go away. Recently, earlier in the summer, the door speakers stopped working so I bought 4 new door speakers and that fixed that issue.
    Edit 2: I just noticed there is a "Red Car with Exclamation Mark" on the MFD. I looked it up and someone said they fixed this by replacing the AC Compressor. I had a problem in 2016 where I had to reset the battery every time to drive it. It ended up being a chipmunk had chewed through the a/c air compressor wiring. I bought a used a/c air compressor off ebay and had it installed for around $500 total ($50 for the used air compressor $450 for toyota labor). I'm not sure if it's related..
    #1 comatoes, Oct 14, 2023
  2. Brian1954
    Brian1954 Active Member
    810
    303
    South Central PA, USA
    The P0A80 trouble code is telling you that there are weak modules in the Hybrid Vehicle (HV) battery. To diagnose it further, I recommend that you use the Dr.Prius app to monitor the voltages in the 14 battery blocks.
    You have three options to fix the problem:
    1. Replace the HV battery with a new OEM battery or aftermarket lithium battery.
    2. Replace the HV battery with a refurbished battery.
    3. Replace the weak (bad) modules in the HV battery.
    There are many threads in this forum discussing these topics. Do a search and learn as much as you can to make an informed decision.
  3. comatoes
    comatoes #GreenLife
    288
    17
    Thanks for the tips. Can I drive it as is or will I realistically face further issues?
  4. Tombukt2
    Tombukt2 Senior Member
    9,105
    1,577
    Durham NC
    You can drive it until you're running on ice engine almost full-time getting about 36 to 39 mi to the gallon if that's your aim. It's time for a new hybrid battery whether you recondition play whack-a-mole buy a new one by a refurbed one all kinds of options I've done all of the above I have not played the whack-a-mole game yet I usually let the rebuilders do that then I just pay there $700 $750 price tag and let it rip until it doesn't.
  5. comatoes
    comatoes #GreenLife
    288
    17
    Thanks for that tip. I just noticed there is a "Red Car with Exclamation Mark" on the MFD. I looked it up and someone said they fixed this by replacing the AC Compressor. I had a problem in 2016 where I had to reset the battery every time to drive it. It ended up being a chipmunk had chewed through the a/c air compressor wiring. I bought a used a/c air compressor off ebay and had it installed for around $500 total ($50 for the used air compressor $450 for toyota labor). I'm not sure if it's related..
  6. txexplorer
    txexplorer Junior Member
    49
    I replaced a single bad module in my 2008 and fixed the codes. It's worth a shot. Cost $30
  7. comatoes
    comatoes #GreenLife
    288
    17
    How did you do it safely? Did you have the equipment?
  8. txexplorer
    49
    I'll admit I wasn't sure I wanted to try and tackle it at first, but after taking the battery out twice and putting it back. It's pretty straightforward and safe, I did most of it without gloves.
    I used an OBD 2 bluetooth and Dr. Prius to figure out the bad Block. I used Car Scanner to get accurate engine and battery codes.
    My code was P3013 which was block 3.
    I followed this video to take the battery out:
    After the battery case was off and the bussbars, I used a multimeter to mark down all the voltages.
    Module 5 in Block 3 was considerably lower than the rest (About 7.2 Volts and the rest were 7.8) and it also discharged faster.
    I swapped that Module out with a refurbished one and that was basically all it took.
    You can read some more that I did on my thread here:
    https://priuschat.com/threads/finally-need-help-red-triangle-slow-acceleration-high-rev-c1310-c1241-other-u-and-c-codes.243989
    I disconnect the 12v battery, then the orange service plug. That cuts the voltage down considerably. The Modules are basically large batteries like a rechargeable AA with a positive and negative only higher voltage.
    You can replace all 28 modules if you want to be good for a couple years at least, but chances are most of your modules are fine and only one or a few need replaced.
    SFO and comatoes like this.
  9. Brian1954
    810
    303
    It all depends on how weak the modules are in the HV battery. You can drive until it quits on you, and then you will need to have it towed somewhere to get fixed.
    Do you plan to fix it yourself, or will you take it to a shop/mechanic to get it fixed?
    Do you know if the HV battery is original or if it worked on previously?
    How long have you owned this car?
  10. comatoes
    comatoes #GreenLife
    288
    17
  11. Brian1954
    810
    303
    To fix it yourself, start by using the Dr.Prius app to determine if any of the 14 blocks in the HV battery are lower voltage than the others.
  12. Tombukt2
    9,105
    1,577
    Durham NC
    We drove our generation too with a bad battery for about I don't know man 5 months and the ice engine just kept coming on longer and longer as the battery SOC went down and down by the time I bit the bullet in ordered the battery and we drove to Apex from Orange county North Carolina we were riding on the gas engine and the battery was just connected to complete the circuit and allow the car to drive I guess It wasn't doing anything and when we pulled it out all the nuts and bus bars were frosted messed up it was horrible It looked bad like real bad and that was that put the new battery in right back to 45 miles of the gallon.
    txexplorer likes this.
  13. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    If being gentle (no rabbit starts/stops), sure just drive it. There are numerous pictures of HV batteies exploding rather quickly, so be careful.
  14. Carall
    Carall Member
    181
    39
    Harrisonburg, VA
    He has the P0A80 code which means that there is more than one weak module the battery pack.
  15. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
  16. Tombukt2
    9,105
    1,577
    Durham NC
    If it's like original battery action well soon as he lifts the silver cover off you'll see exactly the problem when he move some of those black covers up and down I'm pretty sure.
  17. Carall
    Carall Member
    181
    39
    Harrisonburg, VA
    The owner apparently used a generic scanner which cannot communicate with the hybrid battery computer but it did communicate with the hybrid system computer so he could only see the code P0A80, but not the specific battery computer codes. The word powertrain after the code P0A80 in the topic heading confirms this i guess.
    I like this part in the pdf file...
    TYPICAL ENABLING CONDITIONS - TOYOTA’s intellectual property ...which means do what the code P0A80 told you to do, pull some money out of your pocket and visit Toyota dealer... don't even try to fix it.
    #17 Carall, Oct 15, 2023
    Brian1954 likes this.
  18. JohnPrius3005
    JohnPrius3005 Active Member
    418
    226
    California and Hawaii
    If you want real help get techstream to read all the codes and subcodes. That's a first, and cheap, step. But obviously you've done pretty well without it so far ;-) congratulations
  19. Tombukt2
    9,105
    1,577
    Durham NC
    Yep you need a rack set of modules that will play nice with each other how you make that happen is up to you.
  20. comatoes
    comatoes #GreenLife
    288
    17
    Ok update: The day I posted the OP when I went to drive home I heard the loud battery fan. It drove home ok. Today I started it to drive and I made it about 2 miles and I noticed the car stopped charging the battery. I tried to go up a pretty steep hill and it had no power whatsoever. I turned around and drove it home and parked it. The battery was not charged at all. I went to start it again to see if it would and the engine nor the dash light up. I guess it's 100% hosed?
