Red triangle when going around corners.intermittent
Discussion in 'Gen 2 Prius Technical Discussion' started by Charmaine, Jun 10, 2019.
  1. Charmaine
    Charmaine Junior Member
    Mo
    I’ve had 2006 Prius for 6 years and love it. Hybrid replaced 2 years ago. Runs very well but last week red triangle came on when going around a few curves I wasn’t speeding , so I don’t know what is going on. Sometimes the abs light comes on and I’ve been told I need the sensor replaced. I’ve procrastinated on this, so maybe it’s time. Are these expensive.?
    Thank you for any help.
    Charmaine
  2. Mendel Leisk
    42,288
    Check the engine oil level on the dispstick, asap. May or may not be the problem, but good to start with that.
    Weak 12 volt battery can cause odd things too.
    Where there's warning lights there'll be trouble codes stored by the car. If dealership (or 3rd party) can read them, should shed more light.
    Skibob, SFO and bisco like this.
    52,791
    welcome!
    yes
  4. Charmaine
    Mo
    I was low on oil so I added some then had oil changed. The red triangle disappeared. Yay. I’ve got to be more diligent about checking the oil.
