Red triangle when turning
Discussion in 'Gen 2 Prius Main Forum' started by mcslain, Jul 24, 2019.
  1. mcslain
    mcslain Junior Member
    23
    Mohnton, PA
    I am getting the infamous red triangle with exclamation point when I turn. Not all the time, but more commonly with a hard turn. My mechanic is stumped. No codes are returned. Any ideas on what could be causing this?
    Thank you
    Mark
  2. ice9
    ice9 Active Member
    581
    343
    norfolk va
    2018 Prius
    I had that with my old gen 2 Prius, in the last few years I owned it. It also happened intermittently when I decelerated. I thought it was something in the drive train, but I never found out, because by then I was ready to get a new Prius.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Any red TOD should throw a code. Techstream should be able to find that in a history, I would think.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Using Techstream the mechanic should be able to look at the live data and see what the issue is even if there aren't any codes.
    But have you checked the oil level?
    Often hard braking or sharp turns slosh oil around. So if it is low the light comes on.
    Skibob likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,918
    Columbia, SC
    Like mentioned just above...better pull that dipstick....ASAP, like immediately
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Check your oil, like right now! :eek:
    Skibob likes this.
  7. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Low oil is my guess too. How could a mechanic not check the oil level?
    The low oil light would show up on the MFD, not the dash. Could you be so busy looking at the red Triangle you miss the MFD light?
