Red triangle + Yellow exclamation point + VSC; what is happening!?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by M67v, Mar 24, 2019.
  1. Patrick Wong
    18,204
    6,505
    Look for an engine misfire which is unrelated to the inverter coolant pump issue.
  2. M67v
    M67v Junior Member
    49
    Reading, PA
    I’m not sure if my Prius fixed itself, but when I ran it in IG ON today, the liquid in the water pump moved at a quicker rate than when the engine was on. So, I guess that’s fixed now?
    51,892
    must have repaired itself. these cars are totally amazing
    give it a few days, maybe the shaking will go away
    M67v likes this.
  4. M67v
    M67v Junior Member
    49
    Reading, PA
    I think I will err on the side of caution and get the shaking checked out
  5. dolj
    dolj Senior Member
    8,438
    4,288
    Wellington, New Zealand
    You didn't, by any chance, happen to shut the car down before the ICE turned itself off during the initial warm-up phase at the time this violent shaking occurred?
  6. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    :whistle:
    M67v likes this.
  7. M67v
    M67v Junior Member
    49
    Reading, PA
    You know what, I might have at one point or another
  8. dolj
    dolj Senior Member
    8,438
    4,288
    If you did, you can get that violent shaking on restarting.
    It is always a good idea to let it complete that first start up phase before shutting the car off again.
    M67v likes this.
  9. M67v
    M67v Junior Member
    49
    Reading, PA
    And seeing how abused the car was before I got it, I wouldn’t at all be surprised if the previous owners did that several times.
  10. Tedh1979
    Tedh1979 Member
    120
    47
    Fort Wayne, IN
    I'm new on here and I'm just learning and doing what people are telling me so that I can prepare to diagnose a Prius before buying it. The Torque Pro App paid Android version is only $4.95, not $60. I think ericbecky meant to say $6, not $60, because I've seen a lot of people saying $6 on this site, but I paid for it tonight and it was $4.95.
    Also, download Dr. Prius. You can check the state of all of the parts of your battery. Dr. Prius is a free app but you'll need to buy a Bluetooth OBDII scanner. Take time to read the Dr. Prius app's comments on what particular OBDII scanner to buy. He recognizes some as junk and some that don't work with Dr. Prius. I bought a recommended one and it was cheaper on Amazon than it was on eBay oddly. Also, since you need it right away you can get two day shipping. It only cost me $10 for the Bluetooth OBDII scanner. Here is the link:
    Hope you find out the problem(s) of your Prius.
    M67v likes this.
  11. M67v
    M67v Junior Member
    49
    Reading, PA
    I think I know the problem at this point. After I had the spark plugs changed 2 days ago, they scanned my obd2, and they had an error code that had to do with the ABS having a voltage too high or too low. I’m not sure how to fix that though, but so far, no red triangle.
  12. M67v
    M67v Junior Member
    49
    Reading, PA
    The spark plugs fixed the violent shaking by the way
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,431
    3,304
    Madison, Wisconsin
    Ha, ha. Yes I meant $6
    Glad to hear the sharing has gone away with spark plugs and replacement.
    Will be nice to be able to check codes yourself once you have the equipment.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Bad hybrid battery is usually why people sell there Prius. Lots of times the car was taken to the dealer with issues and they pulled obd codes and found a bad hybrid battery. Traded in on the spot they send the car to auction and it ends up on used car lot.
    Many times the hybrid battery will throw a high voltage ground fault code that can be removed temporarily by disconnecting the 12 volt battery and you can drive for a while till it logs again. many many people have been burned buying that kind of car is its very common.
    Car will behave long enough to get off the lot.
    Go to toyota.com/owners and join the forum and list the car's vin. You will see every event the car has seen at a authorized toyota repair center. Lots of times you will see why the car was traded in. You can see the cars repair/maintenance history.
    If you own a G2 prius you need a hybrid capable OBD code reader. Many options where you can use a obd app on your phone and there's the mini vci and theirs the VX DIAG at amazon for $65 that has techstream software that will pull all codes. Whatever you chose it must have toyota techstream software or it wont decode hybrid codes. You going to need one of those asap.
    Without codes its just a guess.
    And you can turn the engine on or off at any time it will not cause shaking. That's a G3 issue.
    You had a misfire code logged.
    How many miles on the car?
    Montgomery likes this.
  15. Matthew Lindsay
    Matthew Lindsay New Member
    Harrisburg, Pennsylvania
    Did you ever figure this one out. I have 2007 prius with 175k. Identical Problem....
  16. M67v
    M67v Junior Member
    49
    Reading, PA
    Nah. For whatever reason, it stopped doing it. I guess it fixed itself somehow
  17. Mahmoud Shehab
    Mahmoud Shehab New Member
    Stanton
    Did you guys figure it out the issue, im getting the same problem after i changed coolant control pump!!!
  18. indianballer
    indianballer New Member
    Merced, CA
    Hey I'm in the same exact position as you. I got my catalytic converter stolen and had a new one installed literally the same morning that all the lights came on. I unplugged my battery and plugged it back in after the catalytic converter was installed to remove the check engine light. I drove about 15 miles and then I got hit with the same cluster of lights that you did. I also unplugged the battery and plugged it back in and was able to drive it again. Now I'm scared it'll happen again. Did you fix your problem by changing the inverter coolant pump? Or did you change the water pump?
  19. ChapmanF
    18,143
    The most consistent successes are going to come to the people who find out what the trouble codes are, rather than just trying to guess from the lights.
  20. M67v
    M67v Junior Member
    49
    Reading, PA
    The crazy thing is I didn’t do anything. It just stopped doing it on its own.
    Anyway I don’t own the car anymore. I sold it six months ago after the engine went bad
