red triangle
Discussion in 'Generation 1 Prius Discussion' started by Andrea Lewis, Aug 22, 2017.
  1. Andrea Lewis
    Andrea Lewis New Member
    Deland, Fl
    2001 Prius
    I
    Help, my car has randomly had the "Triangle of Death" come on and I can drive but acceleration slows. I stop, turn off and back on and the triangle stays on but car drives normal. I usually goes off after I turn off ignition several times but comes on at least once a day! Frustrated, help!
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Most likely your hybrid battery has failed. Trouble lights have fault codes that should be read by an OBD reader to pinpoint the issue.
    Raytheeagle likes this.
  3. Andrea Lewis
    Deland, Fl
    2001 Prius
    I
    That was replaced when I bought the car 5 yrs ago. Just replaced the 12v too. Any other ideas? At my wits end!!
  4. JC91006
    16,936
    8,647
    Did you check your oil level?
  5. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    You need to get a OBDII reader and find out what code its tripping. It could be something really simple and cheap to fix. Get the 12v battery checked just to be sure, its a common cause. There's so many things that can trip the triangle.
