Red Triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DavidY, Jan 20, 2020.
  1. DavidY
    DavidY Reptile Breeder
    NH
    The other day when the temperature outside was in the single digits, I tried to start my 2005 Prius and it wouldn't start and the red triangle with the exclamation point appeared on the dashboard. I tried a couple more times and it started and ran fine. But now whenever I start the car the red triangle appears briefly and then goes away. Could this be a battery issue?
  2. JC91006
    16,936
    8,647
    You should just get that battery tested. It's free at most auto parts places
    Raytheeagle and SFO like this.
  3. DavidY
    NH
    Ok thanks.
  4. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Yes. This is the only warning you get that the car is not happy with the 12 V battery and indicates low 12 V battery voltage. It is the only time the MCL (master caution light) illuminates on startup. Most people never notice it, so good on you!
