Red triangle
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Jul 20, 2021.
  1. lexidium
    lexidium Active Member
    304
    144
    manchester
    Had the red triangle twice now but it says 'no codes' in both autel scanner and torque pro.
    I've cut it off again now.
    Could it be anything to do with overheating in this hot weather?
  2. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    Did it flash quickly then dissappear?
    Could be anything from low oil to intermitten inverter pump failure to an overheating engine...
    Start with checking your oil immediately.
    That is the place to start when seeing an intermittent red triangle flash with no code.
    SFO likes this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Check your oil level. Now.
  4. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Try Dr. Prius app... The two apps you mentioned don't read codes very accurately on Prius, especially sub-codes...
    rogerthat likes this.
  5. lexidium
    304
    144
    manchester
    It stayed on until I cancelled it.
    Will check the oil in the morning
