Reduced Load Carrying Capacity Sticker
Discussion in 'Gen 3 Prius Main Forum' started by PriusOCD, Sep 5, 2010.
  1. PriusOCD
    PriusOCD New Member
    Indiana
    Picked up the car Tuesday - All I can say is...
    Amazing! Congrats to Toyota for the innovation and engineering.
    I did notice a yellow sticker above the drivers door striker, "Caution: Load Carrying Capacity Reduced. Modifications to this vehicle have reduced the original Load Carrying Capacity by 10 lbs (5 kg)."
    It also had a barcode and the VIN. Build date was 05/10.
    Anyone know where the 10 lbs. went?
    Nanoparticles?
    Vaporware?
    Dark Matter?
    Not a big deal, just curious.
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It has something to do with extra weight being added to the car, thereby reducing remaining load carrying capacity.
    It could could be port or dealer added options that added vehicle weight above the factory placard weight on the doorjamb. Or possible someplace else, I can't find the exact regulation in CFR 49 571.
    Mine has a yellow sticker for about the same amount.
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    A similar thing came up in June.
    It was on a '09 Gen II with a 63 lb. load capacity reduction.
    Even tho' that is a lot of weight, there was no "closure" on
    what had been added.
  4. jferris33
    jferris33 Junior Member
    Maryland
    Mine has the exact same sticker. So far I have not seen anything that indicates what the reason is for the reduction of load capacity.
  5. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I wonder if it has something to do with the weight they were tested at for the EPA mpg ratings?
  6. PriusOCD
    PriusOCD New Member
    Indiana
    Only options were factory floor and cargo mats, bumper applique, no dealer installed options. 18 miles when I got it, so sticker must have been installed by factory, distributor, or dealer.
    GVWR is 3980 lbs., passengers and cargo rated at 825 which is standard? Perhaps the GVWR is a baseline and the added options/packages are the reason for the sticker?
    A III, IV, or V sticker (if they have them) might offer some insight:)
    Curious - it was built fairly late in the model year and still required modification.
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    A sunroof model sticker would be interesting, the sunroof adds something like 70 lbs.
    My May/2010 Gen3 Model II yellow sticker says 5kg 11 lbs.
    Only options were factory floor and cargo mats and blue tooth.
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    My V/ATP came with Z1 package. The sticker says 5kg 11lbs.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Boy that sure is some heavy sticker :D
  10. PriusOCD
    PriusOCD New Member
    Indiana
    Stickers are similar but clearly the cars are not the same weight. Seems the GVWR is a bit fuzzy.
    Yep, printed on material harvested from black holes, it creates a gravitomagnetic field. Tailgate a semi and watch your MPG soar.:)
  11. baldeagle
    baldeagle Junior Member
    Oregon
    My guess for where the 10 pounds went (at least in my 2010 V with Nav):
    1 - 5 floor mats
    2 - height adjusting mechanism in drivers seat
    3 - 2 front seat heaters
    4 - Nav console weighs more than alternative
    5 - the new car smell
  12. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    How many of us weigh every item we put in our auto's before travel to insure we are not maxed out! Why worry. H:confused:
  13. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    It's the spare tire. And I don't mean the one made of out rubber ;)
