Reduced weights negative effect on MPG
Discussion in 'Prius c Main Forum' started by jordanzelda23, Jan 17, 2012.
  1. jordanzelda23
    jordanzelda23 New Member
    Republic, MO
    A couple of questions.
    Since the Prius C weighs quite a bit less than the normal Prius will it be more averse to getting worse gas mileage the more you weigh it down with people/cargo? For example if I were going on vacation and drove 500 miles with 3 people in the car and 100+ pounds of luggage, etc. would the Prius C be more effected by that extra weight MPGwise than the normal Prius since it has a smaller engine and weighs less?
    Also, for those who have driven a car weighing similar to the Prius C, do they get blown around the road more than a midsize car in windy weather?
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
  3. Green Tea
    Green Tea Junior Member
    So Cal
    I am also curious about whether or not the car would be blown around easily in winds. We get some pretty strong winds sometimes in So Cal and they are a pain to drive through.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Aerodynamic cars like the Prius tend to suffer more in crosswinds. The new Prius will not be an exception. Being lighter, it will probably move around a bit more.
    As for the penalty for carrying weight, extra weight reduces gas mileage by increasing rolling resistance and requiring more energy to carry uphill. The factors are quite complex, but it's a fair guess that the lighter Prius will show a larger drop in mileage when heavily loaded.
    Tom
  5. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I think from my own experience with a Gen II that the answer is a definite YES.
    By myself cruising at a comfortable 60-ish mph I've gotten a calculated 2.2 GPC (47 mpg) over the first 200,000 miles.
    However loaded down for vacation trips at Interstate speeds in excess of 70 mph that figure drops to ~2.51 GPC (low 40's) in a heartbeat. This is one of the reasons that the new Gen III now uses a more robust 1.8L ICE, it doesn't suffer so much from high-speed driving. In city-type driving though for extended trips <40 mph I can easily get down to ~1.5-1.8 GPC (55-65 mpg) with the older Gen II powertrain.
    Caveat: short trips are death on fuel economy for all ICE / hybrid vehicles. There's no getting around this physical limitation. Electrics are the answer here.
  6. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    The prius is tall and narrow with a fairly high cg. The prius c is lower but narrower, so probably about the same. Both should be better than gen II.
    +1
  7. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    FWIW, about ten years ago, I had a Chevy Silverado with a shell on the back. In cross winds, it was HORRIBLE (it would blow sideways like a semi truck). When I got my Corolla in 2004, it was a huge relief, as it barely moves in cross winds by comparison. I'm assuming it has to do a lot with the car being more aerodynamic. A Prius, however, is shaped more like a fish (notice a lot of smaller cars these days are shaped like fish - tall and narrow). If I was you, I would not have a bias ahead of time that the lightweight c is going to blow "all over the road." My Corolla is 2450lbs. If I was you, I would remain unbiased (for lack of a better word) and wait until you have a chance to drive the Prius c.
  8. Trollbait
    12,827
    It still weighs over a ton, and nearly 700lbs more than the original Insight.
    I don't think it's the aerodynamics since these cars have a side to side profile close to other cars. The real cause of the squirreliness on the highway is do to the alignment. Most cars have one degree toe in as spec to help keep its straight path true. The Prius, gen2 at least, has zero degree for spec. Rolling resistance is reduced since the wheels are straighter, but it also makes it easier for the wind or pavement grooves to move the car from its path.
