Refreshing a 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BigFatGuy, Mar 9, 2018.
  1. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    Took a grinder to the crappy paint on the hood. That took all of a minute, but needed heavy sanding to get out scratches.
    Primer.
    Painted hood (simulated pic here).
    Tore it all apart to remove bumper and headlights.
  2. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    New headlights in, new bumper resting in place (no bolts). I'm calling it a weekend to let the paint dry fully before putting everything back together. Then mask off and spray clear coat next weekend.
    DLC82SV, SFO and Raytheeagle like this.
  3. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    I had the day off and didn't want to wait, so I laid down clear coat last night. I didn't sand between coats, so it's not as smooth as factory. Still, I've seen Maaco paint jobs that are worse, and I paid less, so I'm happy. It's good enough for the high school parking lot.
    Right after spraying:
    Close up:
    Overall, not terrible. Looks great from 20 feet. Still needs a super-fine sand, polish, and definitely washed, but that will be a few days. Black badge, because high school.
    I need to finish wiring the fog lights and the front end will be done. Then it's time for the roof. I've decided to spray gloss black, and add a sharkfin antenna. I'll be going slower there with lots of sanding, so hopefully it comes out smoother.
  4. atlsud
    atlsud Junior Member
    32
    Marietta GA
    nice work on the DIY paint job. How big is the compressor you used?
    BigFatGuy and DLC82SV like this.
  5. ETC(SS)
    7,317
    I was wondering about the compressor size myself.....
    Great Work!
    BigFatGuy likes this.
  6. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    It's a Porter Cable 6 gallon pancake. Yeah, way too small for painting an entire car, but it's fine for the two minutes I'm spraying these parts. And it's paid for, and I'm cheap.
  7. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    Got the windows tinted. Huge difference in heat and I can use lower a/c settings and still survive. Should have done that years ago.
    Fog lights wired up.
    Driving lights are LEDs now.
    Next, fix that nasty roof.
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Man your car is looking great! It always amazes me how much better a car can look with some love and clear headlamp housing!
  9. dolj
    dolj Senior Member
    8,528
    4,331
    Wellington, New Zealand
    I'm interested in an LED upgrade to replace my halogens. Where did you find road legal LED bulbs? The only ones I can find are marked "For off-road use only" so will be uncomfortable, if not down right blinding, for oncoming traffic to use on the road.
    Very keen to get something brighter on my car.
  10. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    Sorry, I said driving lights up there, but meant parking lights. The yellows at the very top of the housing. Got them from RockAuto for cheap.
    I've been busy with other projects, so I haven't finished the roof yet. It's looking like next weekend. I did find some OEM mud flaps in the junkyard. I can't seem to find these for under $50 online, which is annoying for such a simple part. $3 each works for me even if they are well used.
    Also finally got around to adding a 1.5L badge. That added at least 10 hp & 6 MPG.
    donbright likes this.
  11. Patrick Wong
    18,210
    6,511
    My 2007 has halogen bulbs. To improve the high beam visibility I pulled the headlight dimmer relay and used a paper clip as a piece of wire to short the terminals so that when the high beams are on, the low beams also will be on. That was a big improvement for high beams but of course this did nothing for the low beam pattern.
    SFO likes this.
  12. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    I realized I never came back to this. Sanded the snot out of the roof with a hand sander, down to the metal. Then primer, sand again, repeat both. That seemed to get better results, and it looks factory from 10+ feet away instead of 20+.
    I picked up some 17x7 wheels from a Subaru Legacy GT with some 215/50 tires in great shape. $100 on FB marketplace. Only maybe a 5% increase in NVH, and handling increased. Yeah, MPG have probably dropped to ~40 based on what I've read here. I haven't run a full tank to check yet tho.
    Next up is the steering wheel, it's been chewed up at the top by UV. Do people usually replace with stock, or go with a cover?
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Big,
    I was reading this thread and noticed you had asked earlier about the MFD and dash dimming at random times. I had a similar thing going on with one of my Gen 2s and it ended up being the dimmer switch located on the left side of the steering column. All I did was cycle it a few times through it's range and the problem never came back. Maybe it didn't like being left in the same position for years.
    Also, the car is looking great. (y)
    I recently replaced my steering wheel with one from a 2007 parts car. Same reason. It's a higher level package car and had the optional leather steering wheel and was in great condition. I think they're available every now and then on ebay also for about a hundo. The best part was factory fit and finish.
  14. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Looks awesome! Did you paint it yourself? If so what was your method?
  15. BigFatGuy
    BigFatGuy Member
    52
    42
    Oklahoma City
    YouTube. I probably watched 10 hours of people painting vehicles before giving it a go. I used what I had, and bought Harbor Freight for the rest of the equipment. I went higher end on the primer and paint tho.
    I added a few things since. The antenna was deteriorating and looking gross so I bought one for a DOLLAR on eBay. It looks nice and works well.
    The plastic grille insert wasn't quite shaped right (cheapest Rock Auto version), so I pulled it for a metal one from eBay. Not a dollar, but it looks good and should stay in place.
    My fender liner came undone and ground itself against the tire. Cheapo replacement on Rock Auto fits well, plus a bulk pack of retainers. I made a video on how to change it out, but you probably don't need it.
    Aaron Vitolins and SFO like this.
