Refrigerant Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C-in-DC, Apr 10, 2023.
  1. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    You can rent R-410a gauges and the vacuum pump at O'Reilly or I think the others as well for free too.
  2. Mendel Leisk
    42,373
    Out of my depth, but: Toyota Prius AC has a special oil, and Toyota Repair Manual cautions against using gauges that have been used with other oils.
    With AC, my pref is to just leave it to the dealership.
    Paladain55 likes this.
  3. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    @lech auto air conditionin is there a specific video you recommend that fits this particular scenario? I’ve subscribed to your YouTube channel. Great info at the pro level. Might be too daunting a task for a DIYer like myself.
  4. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    I looked at that. All my local parts stores don’t rent them.
  5. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    I’m intending to “prep” for the refrigerant to be charged by the dealer by sealing the high pressure line that was dislodged and evacuating the system. I saw one video where @lech auto air conditionin was recharging a car with refrigerant after oiling the system. The car had been emptied by a dealer using a vacuum pump. He made it look simple but I know I’ll mess it up so I just want to pull the moisture out with a vacuum pump. If I could do it with rental tools I would but the oil req is daunting.
  6. ChapmanF
    19,055
    I'm not sure that'll save the dealer much work, unless you're thinking of pulling the vacuum just as a test to confirm your repair holds before your visit.
    They wouldn't really be doing their job without evacuating the system to their own standards before their own eyes anyway, and whatever vacuum you pulled will likely be lost between you unhooking your connections and them connecting theirs.
  7. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    do want to test the repair and hopefully cut down on costs from the dealer. If this is unneeded redundancy then I guess I’ll just ask them to give me a quote beforehand and let them do the repair.
  8. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Now I’m wondering if it’d be cheaper to take to an independent mechanic on second thought.
    #28 C-in-DC, Apr 25, 2023
  9. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Thank you. I didn’t see the compressor mentioned.
  10. Mendel Leisk
    42,373
    Yeah, concur. Will look again.
  11. Mendel Leisk
    42,373
  12. lech auto air conditionin
    830
    606
    261
    san francisco
    I like the photograph on page 14 what is called the heated charging cylinder. This is how you can tell when they copy and paste from old publications..
    That charging cylinder was used when my dad was young back in the 1950s and 1960s through a little bit the 1970s.
    That is the same charging cylinder by Robinair that I learned on in the late 1970s that was my dads.
    And you really know you’re reading old re-edited refrigerant text if you have one that talks about using R11 as a flushing agent.
  13. rjparker
    rjparker Tu Humilde Sirviente
    11,139
    6,985
    Texas Hill Country
    When somebody asks if a vacuum is needed or just use gauges, it is time to let a pro do this job. Realize this is a variable speed three phase compressor that if ruined will cost you a compressor, condensor, txv and repeat purchases of refrigerant and dryer. Along with a possible high voltage fault for the hybrid system. All of which is normally very reliable.
    Replacing oil in the system if not easy since most is probably still in the system. It is almost sure to have absorbed moisture so you hope a long evacuation removes the moisture along with the air. Otherwise the compressor windings and bearings are at risk.
    Don't even think about the costs if the evaporator gets clogged up. Complete dash removal.
    #33 rjparker, Apr 27, 2023
  14. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Thank you.
  15. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Based on my past experience with the dealer, they’ll claim I have to replace the entire system and charge me $180 for the diagnostic. I’ll refuse the repairs and take it to an independent mechanic who won’t follow toyota procedure. Bye bye ac system.
    I ask dumb questions like do I need a vacuum pump because I’m a slow learner (watching videos, seeking everyone’s knowledge on priuschat and reading the manual, ) and Im not in the automotive industry.
    Without a doubt the above will happen with the dealer so I’ll post what they actually tell me later.
  16. rjparker
    11,139
    6,985
    Texas Hill Country
    I would not be afraid to take it to an independent. Just ask them if they have worked on Prius variable speed electric compressors (which are not typical in conventional cars) and ask what oil if any they would add. I would want to know if they evacuate for an extended period and then charge by weight.
  17. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    so far the ones I’ve asked tell me they don’t use poe or they quote more than the dealer
  18. Paladain55
    414
    172
    The South
    I had a lot to type but essentially you are going to want to remove the ac compressor from the prius and dump out the old moisture absorbed compressor oil, and refill it with the correct amount of nd-11 fluid (or probably the correct way toyota will do it is a new replacement of the compressor only). Try and do it on a day without rain and as little humidity as possible. When you do that, you will want to reconnect the system and get it all readied up to be vacummed as soon as possible to reduce the amount of humidity entering the system with the new compressor oil. Then I would vacuum the system for a couple hours with a new gauge set that is compatible with our system, turn off the low pressure side valve on the gauge, then turn off the vacuum pump and disconnect the pump. Then when you get your refrigerant tank connected you just purge the upper fitting at the gauge to get all the air out of the line, set your refrigerant tank on the weigh in scale, set your tare, and weigh in the correct amount of refrigerant and when you get it charged up and the pressure switch is satisified it will kick on and start running the loop in the refrigerant system. Since its variable speed they say not to worry about the pressures too much if you are doing a fresh evacuation and recharge and just make sure you add the correct amount of refrigerant by weight only.
    *You can also vacuum the system and suck in the correct amount of nd-11 compressor oil through the high side with removal of the shrader valve
    #38 Paladain55, Apr 27, 2023
    C-in-DC and CR94 like this.
  19. C-in-DC
    C-in-DC Member
    487
    69
    Washington D.C.
    Dealer quote for the work is $1,200 and that’s with me supplying the o ring and receiver drier.
    #39 C-in-DC, Apr 28, 2023
  20. rjparker
    11,139
    6,985
    Texas Hill Country
    I hate to sound like a broken record (does anybody get that reference these days) but shop around and....
    ....Personally I would not add oil on a R134a system unless it was obvious oil was all over the place. The dealer will remove the compressor, clean it out, probably put in a new txv and dryer, properly evacuate and charge by weight. A new dryer and extended evacuation is what I would do followed by weighed charging using in R134a.
    Sometimes you have to go further than five miles to find the skilled independent. I would go 60 miles to save $1,000. Its up to you. If you want easy go to the dealer.
    #40 rjparker, Apr 28, 2023
