Refueling issue
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CicilyMJ, Sep 5, 2013.
  1. CicilyMJ
    CicilyMJ New Member
    Vineland, New Jersey
    2013 Prius Plug-in
    I'm new here. Just bought my very first Prius last Friday. After reading a bunch of info on here, I decided to get gas although I still had 1/2 tank. As soon as the attendant began the pump, the pump shut off. He tried a few more times, and the same thing continued to happen. I wasn't sure what was going on and was worried about over filling so I told him to stop. When I got my receipt, it had only taken 1.9 gallons and I was 2 pips shy of full. What's this all about?
  2. Jetsurgn
    Jetsurgn Junior Member
    50
    San Pedro, CA
    Try another station or pump.
    CicilyMJ likes this.
  3. CicilyMJ
    CicilyMJ New Member
    2013 Prius Plug-in
    That's what I was thinking. I was too nervous that something was wrong to try again. Thanks!
  4. fuzzy1
    10,651
    If you lived anywhere but New Jersey or Oregon, I'd suggest fiddling with the pump nozzle, trying different angles, or pulling it half way out. But being in a no-self-service state, trying somewhere else is about your only option.
    Other cars do this too, with varying degrees of problem.
    But it was good of you to leave the attendant with the impression that the PiP's fuel tank is tiny. :LOL:
    chesleyn and CicilyMJ like this.
  5. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    I agree.
    Whenever possible, I return to not only the same station but the same pump. This is a station with a high gasoline turnover so gasoline does not sit in the tanks where there can be water condensation and deterioration of the fuel. Gas pumps need calibration more often than is required to be accurate. The most active pumps are more likely to be calibrated. Pump nozzles wear out and need replacing. All of these are reasons why gasoline seems less expensive some places. On checking it is not always less expensive or as good for your car.
  6. El Dobro
    El Dobro A Member
    7,102
    3,282
    Some attendants like to put the nozzle at the fastest speed. Tell him to put the handle half way.
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :D The first part is good advice. The second part is "at your own risk".
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    Handle halfway to slow the fuel down, not the nozzle halfway in. ;)
  9. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Good luck telling most attendants anything!
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    If you get one that's not a mouth breather, they can usually figure it out. :D
  11. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Here in north Jersey, most don't speak the same language I do!
  12. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)That was my point.
    Lourun likes this.
  13. CicilyMJ
    CicilyMJ New Member
    2013 Prius Plug-in
    LOL, you all are so funny! My husband took it to a different gas station the other day and didn't have a problem. Thanks for the advice!
