Refueling No Longer Resets Trip Meter?
Discussion in 'Gen 2 Prius Main Forum' started by jimolson, Aug 27, 2017.
  1. jimolson
    jimolson Member
    161
    63
    Indianapolis, USA
    My 2009 Prius is equipped with the feature that resets the consumption screen trip meter whenever I do a gas fill-up.
    The vehicle now has 155k miles on it and the trip reset feature has recently stopped working. Even when I do fill ups from a nearly empty tank, the trip meter never resets. This is problematic because, like many owners of high mileage Prii, my gas gauge is no longer very accurate. I've been using the trip meter to confirm the need for a fill up.
    I'm wondering if the recent replacement of my traction battery had something to do with this.
    I've seen other posters in this forum mention this problem. However, I've never seen a response that explains the cause of the problem or its fix.
    Any takers on this?
    BTW, I replaced the traction battery at 151k miles with a new battery stack of Toyota-supplied cells. Prior to the traction battery replacement I'd spent less than $300 on repairs.
  2. JC91006
    16,933
    8,643
    What does new battery stack of Toyota cells mean? You bought a new battery from Toyota?
  3. jimolson
    jimolson Member
    161
    63
    Indianapolis, USA
    I believe AutoBeYours, Inc.of Scottsburg acquires 28 new NiMH cells from Toyota and retrofits them into the existing battery tray. Some electrical components in the tray are reused.
    I also had the cheaper option of a rebuilt battery stack where weak cells in my stack are replaced with stronger used cells from other Prii.
    Because a friend had a bad experience with rebuilt batteries, I did not choose a rebuilt one.
  4. JC91006
    16,933
    8,643
    Toyota sells the batteries complete in a new case, you just need to transfer the ecu and relays over
  5. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    it may be coincidental timing, as I don't believe there is anything HV battery related that would affect your consumption screen trip meter.
    Did you have anything else fixed/replaced? Like the combination meter?
    #5 dolj, Aug 27, 2017
  6. Mendel Leisk
    42,251
    I've never heard of this. Is that different than regular trip meter? For real? (n)
  7. dolj
    dolj Senior Member
    8,633
    4,385
    Yes, it is real – a feature of the Gen II
    The "miles" figure resets every time the tank is filled on 2006-2009 Gen II's. Both the Average MPG and "miles" resets on 2004-2005 Gen II's.
    Both figures can be manually reset at any time by pressing the "Reset" button, shown here on the bottom right.
  8. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    I have been driving my 2007 Gen. 2 Prius since it was new. It has never automatically reset upon filling the gas tank. I have always had to manually press the Reset button on the screen.
  9. dolj
    dolj Senior Member
    8,633
    4,385
    May be you never noticed it. It resets the miles only as soon as you start driving off. I also reset mine manually, as I want to reset the avg mpg as well.
    #9 dolj, Aug 28, 2017
    WilDavis likes this.
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    Perhaps this feature is not on the US Prius. Features and packages available vary. There are at least 4 groups US, Canada, Europe, Japan.
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I used to always reset mine (2009 Gen II) manually, but recent!y have started letting the system do its own thing, and have noticed that it will reset the distance and consumption within about a half mile or so...
    StephenJ likes this.
  12. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Note that if you do NOT hit RESET then the MPG calc is composite average since the last time you hit RESET. I try to hit RESET each tank, but its much harder now as our MFD is on it's last legs and requires about 50 pushes to get RESET.
    We just got into a new problem that our low fuel pip blinky comes on only after 5-gal used.
  13. R-P
    R-P Active Member
    808
    288
    Netherlands
    Same here with a European Gen2. Trip resets automatically (on MFD only), l/100km has to be reset by pushing the reset button on the touchscreen.
  14. bisco
    52,763
    scott clips one of the wires while replacing the battery so you'll be back for a new mfd.:cool:
