Refurbished Battery pack failing again
Discussion in 'Gen 2 Prius Main Forum' started by jichi, Mar 23, 2020.
Tags:
  1. jichi
    jichi Junior Member
    From I what I see that block2 is the one need replacement which means two modules, but I am concerned about how High voltage charge is reaching on each block, is that normal. Another question is I saw a thread that someone managed to use 4th gen modules 2nd gen Prius is it only modules he changed ?.thanks
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Yes, each block consists of 2 modules, but it's typically only one module that fails and causes the voltage to be low.
    Your voltages look pretty normal to me for the year. The highs and lows are going to vary considerably depending on whether the HV battery is in "discharge" or "charge".
    Yes, the Gen 4 modules (Gen 3 also) are physically interchangeable with the Gen 2 modules. If you decide to install Gen 4 modules, you should do all 28 modules. You should also purchase a new 'wire frame #2' from Toyota. This is the wire sensor harness and busbars that fasten along the module terminals.
    SFO and ydpplqbd like this.
  3. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    I see 100% SOC at the bottom of a couple of those screenshots. I'm thinking that cannot be correct. Force-charging to that level would not be advisable for battery longevity.
    ydpplqbd likes this.
  4. George W
    George W Senior Member
    939
    520
    San Antonio
    When you say refurbished, a DIY, or a third party?
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Raytheeagle and dolj like this.
  6. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    ... also, ensure the Gen 4 modules are NiMH and not Li-Ion. Although, if it came to it, I don't believe the Li-Ion modules could accidentally be used. I believe they are a different form factor. But it will scupper your plans.
    [EDIT] SFO beat me to it. :D:p:cool:;)
    [EDIT2] @SFO, Thanks for linking to that Weber U Disassembly And Breakdown Of The 2017 Toyota Prius Li-Ion Battery Video. Very interesting.
    #6 dolj, Mar 24, 2020
    SFO and Raytheeagle like this.
  7. CEBA Battery
    CEBA Battery Junior Member
    Shenzhen, China
    There are two battery models for Prius G4, one is total same with Prius G2/3, another one is Lithium battery type. a
    After getting the same material, you may need to match the parameters of voltage and capacity, make sure to keep Voltage, capacity, and internal resistance inconsistency. So that to prolong battery life. Otherwise, may come to an end soon again.
