Regeneration Question?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Kyle4858, Jul 19, 2013.
  1. Kyle4858
    Kyle4858 Junior Member
    NY
    2013 Prius Plug-in
    I've had the PIP for about 3 months and I'm very happy. Question: I have a long highway commute and I have about 8 miles of the EV range remaining once I get on the highway and switch to ECO mode. There is a large hill that allows me to regenerate about 1.5 miles of EV range bringing my range up to approximately 9.5 miles, as I continue on the flat highway in ECO mode my range slowly drops back down to eight miles over the next five or ten minutes. Is this normal?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I think I know what you are saying. Once you get on the highway and switch to HV mode and the EV miles continue to drop down to 8 miles right?
    That's the behavior I noticed too. A fully charged battery is 85% full. Once you switch into HV mode, PiP will only keep a comfortable 70-75% of the charge. That's probably 8 miles mark for you. A few reason for doing that.
    1) Create room for regen brake
    2) Battery pack can absorb max power. It recharges at slower rate as it approach full (85%)
    2) Prolong battery life
    iplug likes this.
  3. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    It might be trying to maintain the EV miles that you had when you switched to HV mode. You might try staying in EV mode until you get to the bottom of the hill and picked up the extra 1.5 miles.
  4. 3PriusMike
    3,101
    2,420
    Silicon Valley
    Do you "need" the extra EV miles later? If not, don't worry, you got higher gas mpg during that time.
    Mike
  5. Jumpjet
    Jumpjet Member
    77
    25
    Yes it's normal. Once you press the ev button to put you in hv mode, you lock in whatever ev miles you have left. If you want to save the extra 1.5mi you gained, toggle the ev button on and back off again to lock in your new miles.
  6. Kyle4858
    NY
    2013 Prius Plug-in
    Thank you for the responses
