Regenerative braking is not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Igoryan, Jul 13, 2017.
  1. Igoryan
    Igoryan Junior Member
    28
    16
    Chicago, Illinois
    I've got 2005 Prius with 202000 miles.
    My regen braking started to fail intermittently during the day. I have 35 miles morning and evening commutes.
    In the mornings it works most of the time. During the day and in the evenings it mostly doesn't work.
    The typical regeneration sound is missing and I have to apply more force to brake pedal to stop.
    Battery is being far from full at these moments. It is only charging slowly from generator when ICE is running.
    Sometimes it starts working for a few seconds or it works, but regenerates way slower.
    No indicators on the dash or codes.
    At first I was thinking, it was the battery, because I recently got a P0A80 battery failure and red triangle after not using the car for 5 weeks. Battery was charging and discharging quickly, but after a couple of days of normal driving, triangle disappeared and battery started performing as before.
    I am using one of those bluetooth OBDII scanners off ebay, with Torque app.
    It only showed me two codes:
    P0420 - Catalyst System Efficiency Below Threshold
    P0A80 - Powertrain (which is battery failure)
    I've reset the codes and nothing came back.
    It's also very hot these days, around 90 degrees.
    I checked battery temperature sensors readings, everything is below 120F when it happens.
    Any ideas what could be causing this?
    Maybe stroke sensor is starting to fail? But when i press the brake pedal, the screen shows that battery is charging from wheel motors, so the car detects that I am braking, I assume.
    Is something overheating?
    Thanks
    #1 Igoryan, Jul 13, 2017
  2. Michael Cline
    Michael Cline Junior Member
    28
    23
    I just started experiencing exactly the same issue today, it's hot out, and it was charging at around a hundred amps as I descended a steep hill, but by about the bottom of the hill it stopped charging all together and even though the battery is not fully charged it continues to not charge with regenerative braking. It does still charge from the motor however. The fan which cools the traction battery is not running, and it's a few hours later in the day after things have cooled off and it still is not charging via regenerative braking. Torque app does not show any error codes and the car gives no indication of a fault other than that you cannot feel the regenerative braking. I hope this is not early signs of traction battery failure, stressed by rapid charging of the downhill descent. Prius is 2010 3rd Generation with about a hundred twenty thousand miles.
  3. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    I think it is standard behavior for the system to limit maximum charging current from regenerative braking taking into account both battery temperature and state of charge to values less the maximum reached for a cold battery far below full charge.
    Is it possible it considers other variables as well?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Is your inverter coolant pump working? Look in the reservoir while the car is in ready mode and you should see the coolant swirling.
    Also, as I understand it, Torque doesn't come with all the Prius DTC codes. If you haven't installed them, you can find them here on PC with a search.
    Michael Cline likes this.
  5. bisco
    52,694
    clean the battery fan and grille, the hybrid battery may be on its last legs.
  6. Michael Cline
    28
    23
    I verified that the inverter coolant reservoir does swirl when the car is in ready. This was a great suggestion however.
    I have also verified that the radiators are clear of debris.
    I'm continuing the diagnostic under dedicated thread which interested parties can find here: Regen disabled and engine runs constantly in warm weather. | PriusChat
    #6 Michael Cline, May 11, 2019
    jerrymildred likes this.
  7. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Hey, I know, dead thread.
    But I've recently gotten the same issue.
    I suspect it's the 12v, the battery is barely kept alive if I don't drive it for +1 day. Getting red triangle during boot up. It's probably 3 years old.
    However it first appeared when under the front of the car scrapped on a ramp. And it's been intermittent as well, no fault codes.
    Could I have broken an ABS component?
    Torque app shows no regen, just friction braking. It's sketchy enough, hard pedal feel, no abs anti lock brakes. Don't want to find out if the stability control has gone too in the middle of autumn... o_O
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    No, if those warning lights are lit up on the dash, then there ARE codes in the braking ecu's. If you are only using Torque, it cannot talk to most of the ecu's on a Gen 2 Prius.
    See this thread for reviews of OBD apps and devices.
    https://priuschat.com/index.php?threads/232741/
    Some can scan all ecu's, others are more limited.
    Another option is to use a small length of copper wire to jumper two particular pins in the OBD connector, turn the car on, and count which lights flash how many times. Search for "flash codes" to get details.
    Once you have codes, then we can give better advice on how to proceed.
  9. rjparker
    rjparker Tu Humilde Sirviente
    10,884
    6,832
    Texas Hill Country
    Sounds like a Brake Booster fail. Increasingly common and should be throwing codes. Most likely your power brakes, abs and stability control went with it and you are in failsafe mode with reduced braking.
    offib likes this.
  10. ChapmanF
    18,891
    What mr_guy_mann said. Get the trouble codes, using the jumper wire / count blinks method, if you don't have a scan tool that can read them.
    With the history of having scraped on a ramp, it's worth finding out what the codes are; could be an oddball situation, this one.
    Prius trivia fact for the day: the Gen 2 is the only Prius generation with no booster in the brake system.
    offib likes this.
  11. offib
    offib Member
    162
    96
    Dublin
    Four Touring
  12. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Thanks everyone. With limited time I managed to get the 12v replaced with a new battery and codes scanned (none of which the Torque App caught).
    Regen fault, ACTV brake booster solenoid, and "C" Pressure censor. After 80 miles of driving, the lights haven't disappeared - yet.
  13. offib
    offib Member
    162
    96
    Dublin
    Four Touring
    Thank you very much I'll pursue that. It can still stop thankfully.
  14. ChapmanF
    18,891
    The C1259 and C1310 are from the brake ECU, only saying "I've heard there are trouble codes in the HV control ECU, go look there."
    But this scan tool you are using isn't showing you the HV control ECU codes, which are the ones you really need to know what the story is. A better scan tool should retrieve those. We have a thread reviewing some apps and indicating which will work for that.
    For what it's worth, you haven't got even one single code associated with a brake system failure. The regen braking is disabled when the brake system knows there's an HV system code, because it's the HV system that does the regen. That's what's going on.
    offib likes this.
  15. Scott_K
    Scott_K Junior Member
    28
    Central NC
    2014 Prius v wagon
    I love looking up old threads like this describing my EXACT problem and never any update or follow up saying what the fix was....off to the next rabbit hole thread for me!
    offib likes this.
  16. ChapmanF
    18,891
    Do you mean that your EXACT problem is that your car scraped in a ramp, and you have since read your trouble codes using a scan tool that showed you C1259 and C1310 but will not show you the other codes that those codes mean you need to read? 'cause that's the exact problem in this thread.
    Either way, just getting the trouble codes from your car that say what your car's issue is will be the way forward. There are so many possibilities and so many different situations in other people's threads that if you're just skimming a bunch of threads where other people had the same warning lights and their cars acted the same funny, the rabbit holes are of your own making.
    offib, jerrymildred and mr_guy_mann like this.
  17. rjparker
    10,884
    6,832
    Texas Hill Country
    offib likes this.
