Regenerative braking
Discussion in 'Gen 3 Prius Main Forum' started by Eric Slagle, Oct 14, 2012.
  1. Eric Slagle
    Eric Slagle New Member
    Bay Area
    Does anyone know for a fact if regenerative braking is applied while the car is in neutral? Was wondering because while I was gliding on the freeway on neutral and depressed the brakes I noticed the "regen braking meter" on the screen did not fill up, but normally would while on drive mode...
    Thx for your answers in advance
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    FWIR it does not
  3. Eric Slagle
    Bay Area
    cool thx, thats what I thought. Wasn't sure if it was just me but I did kind of noticed when driving/transmission is in "D" and braking the feedback or feeling of the braking doesnt feel the same as the braking while in neutral.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Toyota was legally required to have a Neutral, but you almost NEVER want to be in it.
    You can't generate any charge for the HV Battery in N.
    It is dangerous to the Motor/Generators to go from a speed below 40ish to a speed above 45ish in N (exact MPH number varies by model)
    You can't use regenerative or engine braking in N, only friction braking.
    On the other hand, should you ever suffer the semi mythical Sudden Unintended Acceleration*, N is the right gear.
    * I have, in a Ford minivan
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    What is the harm to the motor/generators (aren't they disconnected in N) from coasting and why is it more harmful above 40 MPH?
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The engine cannot start in N*, so M/G1 can rev to over 10,000 RPMs. Normally this is not an issue, as the engine always starts up to prevent this.
    Nothing is ever disconnected mechanically in the Prius transmission, there are no clutches at all. In N, the M/Gs get/produce no electricaity, so freewheel.
    * M/G1 starts the engine and neither M/G uses or generates electricity in N.
    mad-dog-one likes this.
  7. Eric Slagle
    Bay Area
    Usually on my route to school (about 10miles total trip) on the freeway I have about a 4 mi decline, so as soon as I hit that decline I put the car in (N)eutral and just glide the whole way unless interupted meaning I have to slow down or someone cuts me off... 99% of the time when I know in advance I'll shift from N to D and then apply the brakes so I can cash in on the regenerative braking. Do you think this is bad on the hybrid system? When on the decline I am usually going atleast 70mph to 75mph and would normally shift from neutral to drive and brake so I'm not speeding and usually do that twice for the whole 4 mile decline if I'm not interupted.
  8. bisco
    52,854
    you need a pip for that decline.:D
  9. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I have no clue what a "pip" is but I can't imagine that you are gaining a whole lot in neutral compared to being off throttle for the decline. Whether or not it is damaging to your vehicle, I think it's a waste of effort.
  10. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    In this context, he is referring to the Plug-in Prius, or "PiP". Some of us call each mark on the fuel guage a "pip."
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    While I am not the one to judge, you do need to know this is illegal in CA
    V C Section 21710 Coasting Prohibited
    Going 75, the engine has to be on, and so long as you have the engine on at the start, there is no risk of over reving the Motor/Generators. You still can't charge the HV Battery, but at 75 MPH, 4 miles is not a long time. I do not think you are harming anything, although I don't see any advantage.
    Hitting the brakes while in N, is wasting energy as you can't be getting any regen.
  12. bwilson4web
    16,535
    If you start over the hybrid threshold speed, 42 mph for the older 1.5L Prius and 47 mph for the 1.8L Prius, there is no risk. The engine will already be running and the engine speed will adjust up as needed to keep MG1 in a safe range. However, if the engine is NOT running and you exceed 47 mph, it is possible MG1 might destructively over speed.
    Now two of us, Good Prius Friend Hobbit and I have both 'tickled the monster' and exceeded the hybrid speed in "N" with the ICE off. I went up to ~50 mph and he has done something similar. However, I do not recommend it unless you are prepared to accept the risk.
    When descending a hill large enough to significantly over speed MG1, I will briefly shift into "D" as I pass through the hybrid threshold speed to get the engine running. Then I can shift back into "N" without risk.
  13. Eric Slagle
    Bay Area
    from what I gathered it seems like putting the car in neutral while on freeway speeds and then switching to drive just to brake and reap the regenerative braking wouldn't damage the system, but I will contact Toyota just to make sure it does not void warranty or adds stress to the transmission/hybrid components.
    Although a 4 mile decline doesn't seem like much but its pretty much about half of my 9.3 mile commute to school. I've done about 10 different driving test from home to school (not from school to home) and noticed an increase of about 10mpg per trip while gliding in neutral on the 4 mile decline as opposed to going 65mph on cruise. During the test I never warmed up the vehicle, I always drive immediately as soon as the car is on "ready" and drive softly for the first couple of minutes.
  14. bwilson4web
    16,535
    I would like to suggest getting a Scangauge II and programming in some XGAUGEs to monitor key metrics. Built-in, you'll get ICE rpm, engine coolant, and gallons/hr fuel consumption. But you can add XGAUGEs to see MG1 and battery metrics, to see what is going on. Regardless, welcome to the world of Prius experimenters. <GRINS>
    What is your area of study?
  15. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    Thank you, JimboPalmer and PriusChat! I learn new thing about our Prius on this site regularly.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    One reason I enjoy Priuschat is that everyone is trying to help. I sure hope I got that right!
  17. fuzzy1
    10,707
    I'm not sure asking Toyota will be useful, as the owners manual already forbids this maneuver. For liability reasons -- it is both illegal, and potentially damaging if you botch the speeds and overspeed MG1 -- they really cannot give it their blessing.
    I also don't see it as being all that useful. By carefully controlling the gas pedal and watching the HSI display, you can get rid of the synthetic 'engine compression drag' and effectively get a neutral coast. And if the car rolls up a bit too fast, regenerative braking is available both from the gas pedal and from the brake pedal.
    But practicing shifting to Neutral is a good step in training how to respond to the semi-mythical Sudden Unintended Acceleration. Manual transmission drivers reflexively know what to do, but many people who drive only automatics don't know, especially under stress.
  18. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    Correct me if I am wrong, but I do remember something in my vast readings on this site that 62 mph is the threshold for riding in neutral. Any higher speed than that and you have to make sure the engine is rotating.
    I did a quick search:
    ICE 'running' is ambiguous, because the ICE can turn over with or without burning gas in the HSD drivetrain.
    Label however you want, but
    No petrol, no ICE turn -- up to 62 mph
    No petrol, ICE turning -- no speed limit, the ICE spin is powered by either kinetic or battery energy.
    Read more: http://priuschat.com/threads/maxim-plug-in-prius-glide-speed.102023/#ixzz29OjpgBzd
  19. Selzier
    Selzier Whee!
    148
    51
    I know others have made this point in other posts, but wouldn't popping the car in neutral (especially at higher speeds where the engine would basically shut off the gas intake and use the wheels to keep it going) and "gliding" that way be more fuel INefficient as opposed to keeping light pressure on the gas pedal to keep the artificial "drag" from taking over?
    Or does the Prius operate differently? As in it'll still shut off gas intake into the engine even when gliding in N at high speeds?
  20. fuzzy1
    10,707
    That thread is for the Plug-In, not the regular Prius. Many of us have the regular Liftback equipped with an engine monitor (ScanGauge, Torq, and others), and I don't recall anyone reporting RPM=0 for speeds above 46 mph.
