Regenerative Braking
Discussion in 'Gen 2 Prius Technical Discussion' started by SteveLee, Jan 16, 2013.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    I had thought that in the regenerative braking system that applying the brakes maybe caused some mechanism in or around the wheels to generate electricity. But is it less that braking is generating electricity and more that regerating electricity is resulting in braking or faster deceleration? I'm beginning to think "Regenerative Braking" is kind of a misnomer. Maybe "Regenerative Deceleration" is more accurate.
    I see now that all generated electricity for the system comes from the MG1 and MG2. Whenever pressure is removed from the accelerator the system starts generating electricity charging the HV battery. My question is, does the braking motion, pushing the brake peddle, have any effect on the charging system? How much, when, and how? Can you be accelerating and have a certain amount of pressure on the brake peddle that activates the MG's to generate power? I guess I need to find more detail on how and what each of the MG's do.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Yes, the braking pedal modulates the amount of power that is regenerated by the MG. There are a few factors, such as state of HV battery charge or speed, that determine how the regen vs. friction ratio is changed. You are right in that the regen system can not brake the car to a complete stop. It is inactive below 8 mph.
    If you can run the Prii_dash software (forum is here on PC) you can see how the the friction braking vs. kW of regen power can vary. (Do it while someone else is driving.)
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Your Regenerative Deceleration is correct as well as the Regenerative Braking. If you take your foot off of the gas and decelerate the car will apply a small amount of regeneration to simulate engine drag of non-hybrid cars. As stated above the amount of pressure on the brake pedal will determine the magnitude of regenerative current used for deceleration or braking that is generated by MG2.
  4. SteveLee
    645
    180
    North Carolina
    I
    So it sounds like you area saying there is a varying amount of power generated depending on the amount of pressure on the brake peddle? I thought I read someone, maybe from Patrick, that the level of charge, the amps produced, by the MG is a constant level. It is either charging or it's not. Maybe I'm confused.
  5. nh7o
    1,686
    340
    Hawaii
    Yes. The level of current generated by MG2 varies. I've seen some peaks of 80A when pressing hard on the brake pedal, and it goes all the way down to zero at low speeds.
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    +1 All you have to do is watch the HSI screen in the regen region to the far left and watch it vary as you apply brake pressure. Also watch it as you approach a stop. The regen from MG2 is rarely ever constant.
  7. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Think of it this way, when all is well, you are pushing against a brake pedal simulator. When you push the brake pedal it feels like a normal braking system to you. In reality, the car is watching what your foot is doing and deciding between and how much regenerative braking and/or thermal braking to apply. When a problem arises, the system turns into a conventional system without power assist, just like cars in the olden days.
    Avi
    JMD likes this.
  8. SteveLee
    645
    180
    North Carolina
    I
    I don't think I understand. I haven't seen any regen display on the MFD. Is there a view I haven't seen yet on my 05? How do I get to it. I couldn't find anything about it for the Gen2.
  9. SteveLee
    645
    180
    North Carolina
    I
    What are you using to see the amps output?
  10. SteveLee
    645
    180
    North Carolina
    I
    I have felt different sensations in the braking process but didn't know exactly what they were. It's starting to make more sense now I think. Is there an article or white paper on this somewhere? I haven't been able to locate one yet.
  11. Avi's Advanced Automotive
    776
    363
    Try this link.
    Avi
    SteveLee, seckwielen and JMD like this.
  12. nh7o
    1,686
    340
    Hawaii
  13. fuzzy1
    10,713
    But his 2005 doesn't have the HSI screen. That arrived with the 2010 model.
    jdcollins5 likes this.
  14. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    No HSI screen on the gen2 only gen3, this could confuse the OP.
  15. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Sorry, my mistake. The OP will need a ScanGaugeII or other device to see the regen current flow then.
  16. Britprius
    5,194
    1,924
    I am sure we all make this sort of mistake when we move into another forum than our own vehicle, I know I have.
    John (Britprius)
    babybird likes this.
  17. SteveLee
    645
    180
    North Carolina
    I
    Thanks. That helps me better understand the process.
  18. SteveLee
    645
    180
    North Carolina
    I
  19. SteveLee
    645
    180
    North Carolina
    I
    No problem. I thought that may be the case but wasn't sure.
  20. SteveLee
    645
    180
    North Carolina
    I
    So, there is a varying amount of electricity generated depending on the level of the peddle within the range of motion. Light peddle application allows a little power generation and further peddle application allows more power generation, also depending on other factors processed by the computer.? So it is possible to maintain speed with the accelerator peddle while generating power with the slightly depressed brake peddle? Not that I think that would be a good practice, just saying, for a better understanding of the capabilities.
