Registering TPMS IDs
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by BigFan, Nov 2, 2016.
  1. Mendel Leisk
    42,364
    It's funny though: the problem with flat detection system is eclipsing the problem with flats.
    padroo, RCO and Jeppefinn like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sure is ironic, (not Ioniq)!
    Jeppefinn and Mendel Leisk like this.
  3. Kiril
    Kiril Junior Member
    27
    34
    Sofia
    Excel
    I changed tires recently and got the same bad behavior from TPMS. Apparently the winter set is programmed in as set 2 as I asked the dealer to do. But for some reason the car is not switching to the main set. I read the manual again and it says no registration is needed if you have both sets registered.
    May be I need to do initialization when I am far away from home. I cannot find switch or anything to ask the car to use "Main Tire" set. You can see on top I have two sets registered and both have 4 tires. Aparently "Sensor ID Status" points to the 2nd set.....
    The picture attached is screenshot from Techstream at home. The car is happy as the winter tires are on a rack beside it.....
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I think there is an error in the manual about Prius supporting two sets. There are Toyotas that have a switch in the glove compartment to select which set is active. But this is the first that I've heard that a Prius has the capability.
    RCO and Mendel Leisk like this.
  5. Mendel Leisk
    42,364
    Yeah, anytime different sensors are brought to the car they need to be introduced, or reintroduced, AFAIK.
    RCO likes this.
  6. Kiril
    Kiril Junior Member
    27
    34
    Sofia
    Excel
    No it is not an error. When I clicked the "Register IDs" button in tech stream it asked me which set I want to register. Techstream also lists two sets (I am not sure how to get the ID codes of the first set).... The manual explains about these two sets on several pages in different chapters. It is not a typo on one page. It is also explained in different languages as I read both the English and Bulgarian manual. Both say I should not do anything special when changing tires with rims.....
    I will play a bit with techstream in office tomorrow away from my winter tires and will visit the dealer ....may be I am missing something about this switch. It seems all new European vehicles after 2014 have a requirement for TPMS and most support two sets.....
  7. Kiril
    Kiril Junior Member
    27
    34
    Sofia
    Excel
    Here is the text from the English manual claiming I need not do anything when changing tires
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    It will be great if you can actually use two sets of TPMS sensors. But I still think you need a switch to select the active set. Prius has never had the switch in the past, and automatic switching would be a new feature.
    RCO likes this.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    The US 2017 Prius manual says this:
    i guess it remembers which wheel has which tire?
    This too.
  10. Mendel Leisk
    42,364
    I wonder if the bit in the red box needs some editorial attention? As far as I know, the car identifies four wheels, doesn't much care where they are, as long as they're within range. They could be on the car in their usual positions, in a stack beside the car, or piled into the hatch.
    RCO likes this.
  11. Elektroingenieur
    2,515
    3,288
    Three Touring
    The European edition of the Repair Manual (available by subscription to toyota-tech.eu) describes such an “ID Switching Function” and gives this procedure to switch between the two sets of stored transmitter IDs:
    1. Install the tires and wheels that use the correct IDs to the vehicle.
    2. Turn the power switch on (IG).
    3. Operate the steering pad switch assembly, select "TPMS" on the multi-information display and operate the "ENTER" switch (steering pad switch assembly) on and off 3 times within 3 seconds (press/release → press/release → press/release).
    4. Check the answer-back function of the tire pressure warning light.
    Tech Tips: Make sure that the tire pressure warning light illuminates for 3 seconds and turns off for 0.5 seconds 3 times.​
    None of this information appears in the U.S. edition of the Repair Manual.
    No, it’s correct that after rotating the tires—which should also involve adjusting the air pressure in each tire, since the front and rear pressures are different—the technician should do the initialization procedure, which stores the current pressure reading from each transmitter for reference. Initialization can be done without a Toyota Techstream system and is different from registration, which changes the stored transmitter IDs.
    RCO, Prodigyplace, Kiril and 2 others like this.
  12. Mendel Leisk
    42,364
    Ok, that makes sense. It's storing values for specific sensors, and depending on their being front or rear, the pressures "should" be set a little different. I'm a little incredulous though, for a couple of reasons.
    First off, and this is just personal: since I'm doing my own rotations, I got tired of adjusting the pressures for the front/rear difference, and opted to set them all to the same pressure, 2~3 pounds above the front tire pressure spec.
    Secondly, owners have reported that the pressures need to drop about 25% from the set pressures, which makes the the front/rear difference of 1~2 pounds sort of insignificant.
    RCO and krmcg like this.
  13. Kiril
    Kiril Junior Member
    27
    34
    Sofia
    Excel
    Thanks a lot! This is great to read. I wonder why this simple instruction is not in the "User Manual". At least they should mention that the two sets do not switch automatically.....
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    So anybody have an American 2017/2018 to check this out? Probably have to use Techstream to register a second set before it will show up on the selection menu.
  15. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...no I don't even know anybody with a Gen4...got 2 new Prius v's on the block though
  16. Kiril
    Kiril Junior Member
    27
    34
    Sofia
    Excel
    I am happy to report that triple pressing the "Central" button while in TPMS menu turned off the TPMS warning light after about hslf a minute of blinking.
    So it seems indeed to have switched the set to "Main" from "2nd". I will report if something goes wrong in the next days as the prior discussion indicates that some time is needed by TPMS to actually do it's thing. I can also check in Tehcstream if the active set i snow "Main"
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    Thanks for reporting back.
    RCO likes this.
  18. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Tentative proof only because if you reset the warning light (on a Gen2/3) it can take a while for the computer to reassess if the codes are correct.
    RCO likes this.
  19. Prodigyplace
    12,720
    11,852
    Central Virginia
    In post 89 I quoted the Gen 4 manual that says 20 minutes of driving.
    RCO likes this.
  20. padroo
    padroo Senior Member
    2,763
    2,253
    I ran into a problem with my Autel cloned TPMS sensors. I installed my new wheels with the cloned sensors and immediately went on vacation. About 20 minutes from home I got a TPMS warning light. I think it is still reading the old sensors that are stored in my garage because the light goes back out when the car is in the garage.
    I am still trying to figure it out.
