Regretting not getting leather
Discussion in 'Gen 3 Prius Main Forum' started by RamesesThe2nd, May 7, 2013.
  1. RamesesThe2nd
    RamesesThe2nd 2012 Prius III - Classic Silver Mettalic
    73
    17
    Chicago, Illinois
    Sure. It sounds like Prius is not the right car for you. Again, if you can't live without leather spend $1500 and get after market leather.
  2. RamesesThe2nd
    73
    17
    Chicago, Illinois
    Also, even with leather Prius will still be a normal car, i.e., not a luxury car. I don't think anyone will confuse it for BMW or Lexus. It is an awesome car and I would probably but it again, given the choice to pick between Prius and a Luxury brand.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Perforated leather is an option with Katzkins. I got it on the seating surfaces.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I don't see spending hundreds or thousand or so to put leather on a driver's seat that has mechanical adjust lever and NO TILT adjustability. These basic fabric seats are worth $100 or so in covers, that's it.
  5. Tideland Prius
    16,683
    Keep in mind that Katzkin does offer a ventilated seat option too, not just heated seats....
    Or you could keep the money and IF the cloth seats wear out, replace them with Katzkins. If they hold up, you've saved money =).
    RamesesThe2nd likes this.
  6. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Anyone know if we can just order a center console leather cover from katzkin or some other brand? The center console is the only piece that REALLY bugs me because the cloth looks super cheap and like it will wear out pretty fast. Plus idk why all the cloth in the car is a charcoal color, and the center console is black(n)
    I figure doing the console is the one piece that I can do fairly easily.
  7. RamesesThe2nd
    73
    17
    Chicago, Illinois
    Yeah. I don't understand either why my center console is black. The quality of cloth on center console also looks cheaper than other cloth in the car.
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Many say light colored leather and interior is cooler in hot sun.
  9. RamesesThe2nd
    73
    17
    Chicago, Illinois
    Leather is not better. I had both leather and cloth seats in my previous Toyotas. Leather looks better and it is easier to clean. Cloth feels better and IMO it is more comfortable than leather. I live in Chicago. During the past winter, my cloth seats were always comfortable in below freezing temperature and I didn't really need heated seats. If I had leather, I would definitely need heated seats. I am looking for leather because it looks nicer and cloth looks cheap. Cloth and Leather both have their own pros and cons. Leather is not superior to cloth and vice versa.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    How is it sticking your elbow on the center console? It's nothing but thin fabric over hard plastic. Several hours buying material / sewing, strapped on armrest pad - (did I already post this here??) Foam by the shifter just put on for right knee. Have to move seat out of preferred setting due to scant steering wheel adj range, result, lacking thigh support. At least console / pad there to help out. I cannot call this car 'tall friendly' due to the inadequate steering wheel adjustment range both tilt and telescoping.
  11. Tideland Prius
    16,683
    The leather on the 2010-2011 were perforated. The SofTex isn't so I don't know if it's any better or worse in the summer than perforated leather. Given that it's a solid piece, I'm guessing it performs the same as non-perforated leather surfaces unless SofTex itself is breathable.
  12. p00kienrayray
    720
    135
    Long Beach, CA
    OP, the local dealer near me is quoting $1,188 installed OTD via local upholstery shop. I don't know if katzkin is used. The dealer parts guy said they cut their own leather from scratch, but $1,200 sounds too low for that kind of job so I'm thinking its a pre-cut kit.
  13. michinnom
    michinnom Member
    162
    29
    You're not missing anything since it's not even leather, it's pleather. yes, man made fake pleather. you're better off getting an aftermarket product as others have suggested.
  14. RamesesThe2nd
    73
    17
    Chicago, Illinois
    I posted earlier. A local dealer (Lombard Toyota) in my area quoted me $1370 for heated leather seats and $1100ish for seats without seat heaters. They didn't mention Katzkin, but as you said, I am sure they are using some pre-cut kit.
  15. teamsc10190
    teamsc10190 Stereo Prii (2011 and 2006)
    145
    64
    Hot or cold; cloth seats are more comfortable than leather, but leather wears better and cleans easier. If you plan on keeping your car a long time, I'd personally opt for leather seats because they hold up better. That's why I bought a used 2011 with leather in 2012: I didn't want cloth or vinyl seats.
    I'd avoid aftermarket leather for the sole reason that the car has seat airbags. Even that the aftermarket suppliers can show you a video of an airbag deploying through the seat cover; how can you be assured that the split seam is properly positioned, and yields at the right time, pressure and direction in accordance with Toyota's design considerations for the proper operation of the seat airbag? How would aftermarket suppliers be aware of Toyota's design considerations? The answer is that they can't because that information is proprietary to Toyota. It's not an open platform architecture.
    Aftermarket leather suppliers are in the cut and sew business, not safety engineering. A deployment differential of hundredths of a second can be the difference between an airbag that performs as designed or one that doesn't. An airbag inflator is a pyrotechnic device (essentially a solid rocket motor) that deploys the bag at 150 to 250 miles per hour. A projectile moving at that speed that presents at the wrong angle or timing can do significant damage.
    If you have confidence that the cut and sew shop has done their homework to reverse engineer Toyota's safety design and properly validated it with instrumented crash dummies in barrier impacts with actual cas as Toyota needs to do, then you should feel good about aftermarket seat covers. If you have doubts that a cut and sew shop could have such expertise or has made the extraordinary investment to validate performance, then maybe you'd be better to consider a car with factory leather.
    If you're comfortable to roll the dice, go for it, but don't turn around and run for a lawyer if God forbid you have the occasion to discover that the cut and sew shop didn't have the necessary know-how. Good luck with your lawyer's argument that Toyota was responsible for non-performance of a safety system that you and your cut and sew shop modified.
    There are lots of things I'd go to the aftermarket for, but I draw the line with safety systems. The fact is; you don't know what you don't know and IT CAN happen to you.
  16. RamesesThe2nd
    73
    17
    Chicago, Illinois
    I hear you, but it is too late for me. I have already bought a car with cloth seats. I understand the safety issue with after market leather and, for this very reason, I might just stick with the cloth seats. Leather is nice to have, but not a must have for me. I think I like the idea to stick with cloth for now and see how long it lasts. If I feel 5 years from now that my cloth seats are mostly worn out, I will switch to leather then. I am probably not going to take any action on it before winter. If at the end of the summer, I am still heavily inclined to get leather, I will upgrade.
    JMD likes this.
  17. teamsc10190
    145
    64
    You may want to consider a seat cover "vest" that avoids the airbag deployment area and protects the primary sit area.
  18. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I bought something very similar for my BMW (from BMW) several years ago and it's been very comfortable.
  19. RamesesThe2nd
    73
    17
    Chicago, Illinois
    This sheep skin vest looks great. I think I just need to get two for front seats. I see a lot of vests from BMW and Jeep when I search online and nothing for Toyota (including Prius). Is this site reliable to order from? I couldn't find any info and reviews on sheepskinstuff.com online.
  20. teamsc10190
    145
    64
    I've never done business with them so I couldn't vouch for this company or their products. Sorry. Perhaps someone else on the forum can offer some guidance for this company.
