Regular Battery Charging
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, Nov 15, 2018.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Forgive me if I'm wrong but I'm pretty sure in a non-hybrid car the car battery is charged by the engine.
    But what about the Prime because I HARDLY ever use the engine and we all still use the regular battery for the infotanmint, screen, phone charging etc. Should I run the engine or did Toyota think about this and the battery has alternative like when you chrg the traction battery does some of the juice go into the regular batter?.
    Hopefully, this wasn't confusing to read but
    Traction Batter= Battery that sends electric to the motor to over the car
    Regular Battery= Standard car battery found in almost every car
  2. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    I'm pretty sure the "regular" battery is charged by the "traction" battery when the engine isn't running (Even when the car isn't being charged by AC).
    benagi and EyePrime like this.
  3. Tideland Prius
    16,683
    MG1 is the "alternator" substitute. It'll keep the 12V battery charged, regardless of power source (engine or HV/Traction battery)
    What he said ^^
    #3 Tideland Prius, Nov 16, 2018
    EyePrime likes this.
  4. EyePrime
    268
    115
    2018 Prius Prime
    Thx
  5. bisco
    52,912
    toyota are genius!(y)
    Piwacet likes this.
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I don't believe this is correct. MG1 is a high voltage motor/generator and thus will charge the traction battery, not the 12V battery. The only way to charge the 12V battery is by using the power supply that runs off the traction battery, exactly as xray22 said.
    I haven't been able to find the rating of this power supply for the Prime, but it was rated at 100A on my 2004 Prius.
    I commonly charge my R/C airplane batteries off the 12V battery. If I charge a lot of them, I'll put the car in Ready mode for 10-20 minutes to let the 12V battery charge up. This definitely charges the 12V battery since it's voltage changes from something like 11.8V to something like 14.1V but it doesn't start the engine. In fact, if I shut off the A/C and headlights, you'd never know the car was on.
  7. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    WeberAuto Prof John Kelly says in the battery removal video (around min 22) that the charger has built-in DC to DC converter and output 14 V to charge the 12 V battery while charging. He also showed low voltage connector in the front part of the high voltage battery.
    Chazz8 and Tideland Prius like this.
  8. Tideland Prius
    16,683
    Gah. I'm losing it!!
    Yeah what you said sounds right. :oops:
    VTBIGDOG and jerrymildred like this.
  9. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    12V battery is charged by traction large battery. So no worries.
  10. Washingtonian
    Washingtonian Senior Member
    726
    621
    A minor worry. I understand that the 12V is charged by the traction battery. Looks like it is only while the traction battery is being charged. So if I park my car for a month or two, looks like the 12V will lose its charge unless I connect a battery tender to it. I recently did park it for 60 days and left the traction battery discharged; then hooked it to the charger the first day I got back. I am guessing that I didn't need the battery tender because the 12V would have been also recharged at that time. Is that correct?
  11. Lee Jay
    5,850
    4,036
    Or the car is in ready mode.
  12. Roy2001
    371
    158
    Sacramento, CA
    Yeah you could disconnect the 12V battery for more than a month.
  13. Washingtonian
    726
    621
    I am afraid that some of the settings that I or the dealer have done (like removing back up beeps) might be lost if I did that.
  14. benagi
    benagi Active Member
    525
    280
    Utah
    I don’t think that would change but all your presets on the radio would be lost.
  15. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    I heard the same thing from Kelly. However when I check my 12 volt battery during charging of the traction battery in my Prius Prime, it does not show that the 12 volt battery is charging. When the Prime is in READY the 12 volt battery always is being charged.
  16. bisco
    52,912
    it's funny that this isn't well known yet, after two years on the market
  17. CraigCSJ
    287
    144
    San Bernardino, CA
    In my Prius Plugin 2015 the 12 volt battery is charged during the time the traction battery is being charged. Wonder why Toyota changed this for the Prime.
  18. bisco
    52,912
    this came up in another thread.
    my theory; they either didn't want to spend the money on the wiring to get to the 12v now under the hood, or they saw it as an unnecessary feature that didn't help sell cars, and a good place to cut costs.
    it's nice to have, but the lift back does okay without it, and toyota is the king of decontenting
