Reinforcement for front apron?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MrPete, Oct 31, 2023.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    I have an almost-new front apron (front most black plastic underneath.)
    Already, it is showing signs of stress and wear.
    The plastic corners from main flat to the depressed bolt holes are VERY thin.
    Has anyone seen, or tried, anything to reinforce this part? I am thinking of melting more plastic into those edges/ corners.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    yes, you need a plastic welder kit..
    https://amzn.to/49dRpBz
    I have both the soldering iron style and what I call a plastic stapler. You might get away with a small blow torch and zip ties but a welder would be best. Zip ties are very strong plastic when used to weld or strengthen other plastics!
  3. MrPete
    507
    194
    Colorado, USA
    Want it to match. So this is PP (polypropylene).
    I already own plenty of precision heating tools. Good idea on zip ties... I probably have a hundred PP zip ties.
    Have you done this on the apron?
  4. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    yep. the screw hole on the wheel well broke, had to add zip ties with plastic welding iron and was al good since.
  5. Mendel Leisk
    42,315
    Rolling right up to concrete curb stops is tough on it: the front apron pushes up on and past the curb, then royally snags when you reverse off it (design fail, Toyota). I’ve taken mine off and patched with two-part epoxy 2~3 times now, still holding together. Welding the plastic sounds superior though.
    MrPete likes this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    Use these;
    1/4" x 1" Stainless Steel EPDM Bonded Sealing Washers (50 Pack), 1" OD Neoprene Backed Corrosion Resistant Load Distribution Water Tight Seal by Bolt Dropper
  7. MrPete
    507
    194
    Colorado, USA
    UGH. I just checked: Zip Ties are NOT normally PP! They are nylon. Use of zip ties is very questionable: most likely the plastics can separate under stress.
    Two alternatives:
    1) Many plastic items have spare "tabs" from manufacturing, that can be taken and used for plastic welding as needed :)
    2) I just ordered a bunch of PP welding rods online, very cheap. I also ordered stainless mesh for embedding in plastic welds... adds a lot of strength.
    I'm going to do some plastic welding today. Will take pix. We'll see how it goes.
  8. MrPete
    507
    194
    Colorado, USA
    (I also now have a LOT of spare large sheets of PP -- my old bumper cover, plus one entire spare! Anybody need a Gen3 front bumper cover, pre-painted in 4T8 Sandy Beach Metallic?)
  9. MrPete
    507
    194
    Colorado, USA
