Reinvesting in Prius 3 with 187k
Discussion in 'Gen 3 Prius Main Forum' started by Jose Duque, Apr 25, 2018.
  1. Colm01
    Colm01 Member
    83
    75
    Wilmington, DE
  2. Jose Duque
    Jose Duque Junior Member
    Houston
    I meant that “IF” the light kept coming on then I would be concerned and got rid of the car as you have suggested
  3. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Thanks for the link. There will likely be a stipulation that Conicelli Toyota does the install (they were closed when I called to confirm). That would be around 4-5 hours of labor at dealership rates, which would likely add ~$450-$600 to the cost. $2,600-$2,800 installed seems to be the going rate, which is lower than what the OP was quoted.
    Kansas City has the lowest rate that I've seen at $2,200 installed, but the travel costs would eat up the savings. Ditto with Conicelli Toyota in Pennsylvania. If the OP decides to go the OEM route, it's best to find a competitive rate in the Houston area.
    As a reminder, double check the details about the core charge. The dealership will need on an OEM core in return for refunding the core charge, which will be around $1,300. The OP could go with Houston Hybrid Battery, referenced in post #6 (~$1,400 installed with a 2 year warranty for a reconditioned battery), which is a pretty good price. But then, Jose Duque won't be able to purchase an OEM battery from a dealer as a plan B, without paying the core charge in the future.
  4. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
  5. MelonPrius
    839
    516
    Nevada
    If that price holds true for gen3, that would be the lowest price I've seen, especially when you factor in mobile installation. (That's the price for a gen2 battery- as per the link.) I'm hoping that these prices continue to drop.
    Hometown Hybrids and scona like this.
  6. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Actually, that would be the installed 'out the door' price for both Gen2 and Gen3 HV Batteries (NEW OEM).
    Pricing Table - Click Here
    amos, Bay Stater and Raytheeagle like this.
  7. Prodigyplace
    12,566
    11,780
    Central Virginia
    Toyota battery prices dropped $400 in January. @ericbecky and others here have confirmed that. We have seen a couple of dealers online list batteries for $1625 plus core but nobody ships them.
    Installation would be extra.
  8. MelonPrius
    839
    516
    Nevada
    Yep. Just assume the installation runs around $500-$600, but you'll still need to travel there.
  9. Prodigyplace
    12,566
    11,780
    Central Virginia
    Umm. I see the price as for either a Gen 2 or a Gen 3 battery pack. That are not offering one of each for that price. ;)
    Hometown Hybrids likes this.
  10. Jose Duque
    Houston
    I wanted to give everyone an update. I called Houston Hybrid Battery as suggestion by Kingsman and they were top notch. They told me to make sure I got the 12 Volt Battery at the dealership since they tend to hold better over a period of time. I was given the option of paying 850 with a one year unlimited mile warranty for changing out the contacts and reprogramming the software which what he told me is all that needed. However I went with the 1400 2 year unlimited miles warranty where did a little bit more on the battery. I felt that since I was looking at a 400k cost with paying 1400 I was already ahead. Thanks Kingsman fr the number and everyone else for your suggestions!
    Bay Stater, Raytheeagle and bisco like this.
  11. bisco
    51,950
    all the best!(y)
  12. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Please report back here in the future if something fails or you have issues with the warranty.
    You also needed a 12v battery, or was this for future reference?
    Curious what the extra $650 in cost (1 yr vs 2yr) accomplishes in term of 'a little more to the battery', beyond the extended warranty of course.
    Never heard of reprogramming the software before, that already sounds a little funny :cautious:
    Did someone clean your HV battery fan before or after the installation, a very important thing to do and many include that in the price (y)
    I believe Matt @Texas Hybrid Batteries mentioned cleaning the MAF sensor and intake whenever they do a HV battery replacement, did you notice anyone poking around under the hood?
    I know the leap from $1400 to $2300 is great, but was there another reason for going with the used battery over a new battery?
    Bay Stater, Grit and Raytheeagle like this.
  13. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    My guess is it will die for real this summer when it's stressed the most.
  14. GFO
    GFO Member
    75
    50
    Larkspur
    With close to 200K on the clock and you driving 35K miles a year, I'd not invest $4k into the car, not even $3k. Maybe $2k at most. though it really depends on what condition the rest of the car is, if the engine is running strong and the interior/exterior are still cherry, then that changes things some.
    I'd seriously consider trading it in soon for another Prius, doesn't even have to be new if $$$ is an issue. You could probably find a nice used 2014-2015 with low miles for a lot less than a new Prius if you shopped around aggressively. Even a 2016 with low miles if you're set on the 4th gen.
    edit: Never mind, didn't read the update, see you got a great deal. Nice.
    #34 GFO, May 1, 2018
    Sporin likes this.
  15. Keepdriving
    Keepdriving Junior Member
    35
    27
    Palatine
    Very possible. It was like late July last year on a real hot day the dreaded check hybrid system warning first came on. So far, now that I don’t have to use the heater, it’s back up to 52, 53 mpg. I’ll post what happens this summer if anyone’s interested.
  16. Keepdriving
    35
    27
    Palatine
