Relation of wheel and hybrid system
Discussion in 'Prius c Accessories and Modifications' started by rhythm0699, Apr 6, 2018.
  1. rhythm0699
    rhythm0699 New Member
    Bangladesh
    I heard people are saying that , if I change my stock wheels/rims of a hybrid car, then I won't get the full benefit of hybrid system and it may cause hybrid system failure. the reason is the battery is charged by regenerative force produced by braking force. is it true ? or I can use aftermarket wheels on my car ?
    SM-G935F ?
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Aftermarket wheels and rims are ok to use on the C and they will not damage your hybrid system. You can find many pictures of Prius C's here on this site running aftermarket rims / wheels.
    rhythm0699 likes this.
  3. rhythm0699
    Bangladesh
    is it only for c or i can use aftermarket wheels to any other hybrid vehicle ? thanks for your reply.
    SM-G935F ?
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Aftermarket rims / tires are ok on Toyota hybrids.
    I do not know about other hybrids.
    Unless your really want aftermarket rims / tires, I would save the money for a replacement hybrid battery. I may be wrong, but it seems many people have to replace it on the Prius C when the car is getting to be 5 or 6 years old and has 100-150,000 miles.
  5. ChapmanF
    19,037
    I think you've been hearing people with a weird sense of humor. There isn't any part of the regen braking system that depends especially on the wheels. As in any car, you may change your efficiency if you get different wheels with significantly different weight or dimensions. But really, the hybrid system can't tell what wheels you've got on the car.
    -Chap
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Heavier wheel and tires will reduce MPG, but they will not harm the car.
  7. rhythm0699
    Bangladesh
    okay got it. thanks .
    SM-G935F ?
